Topic: Data logging problem - error free code but no file written to SD card (Read 329 times) previous topic - next topic
Grasshopper04
I am new to arduino.  I have built a C02 sensor using info. from the link below:
 http://www.osbss.com/tutorials/co%E2%82%82-sensor/
The code is producing no errors (now!) and the SD card being used is a new SanDisk MicroSD 16gb card.  [These are supplied formatted so I have not followed the advise given in the sticky.]  Having put the card into the MacBook no files were found/seen.  The C02 sensor light was flashing showing C02 was being sensed by the green LED was flashing 3 times indicating an issue to with the card.
I will post the code below.  Please could you take a look?  I have checked the pins. I am wondering what other checks can be done to try to find the problem.
Many thanks.
// OSBSS CO2 data logger based on SenseAir K-30 1% CO2 sensor
// Communication with sensor using I2C protocol
// Last edited on May 29, 2015 - old SdFat code
#include <EEPROM.h>
#include <DS3234lib3.h>
#include <PowerSaver.h>
#include <Wire.h>
#include <SdFat.h>
// Launch Variables   ******************************
long interval = 5;  // set logging interval in SECONDS, eg: set 300 seconds for an interval of 5 mins
int dayStart = 8, hourStart = 16, minStart = 30;    // define logger start time: day of the month, hour, minute
char filename[15] = "output.csv";    // Set filename Format: "12345678.123". Cannot be more than 8 characters in length, contain spaces or begin with a number
// Global objects and variables   ******************************
PowerSaver chip;   // declare object for PowerSaver class
DS3234 RTC;    // declare object for DS3234 class
SdFat sd; // declare object for SdFat class
SdFile file; // declare object for SdFile class
#define POWER 3    // pin 3 supplies power to microSD card breakout
#define LED 7  // pin 7 controls LED
int SDcsPin = 9; // pin 9 is CS pin for MicroSD breakout
int CO2ppm = 0;
int _CO2ppm;
// ISR ****************************************************************
ISR(PCINT0_vect)  // Interrupt Vector Routine to be executed when pin 8 receives an interrupt.
  //PORTB ^= (1<<PORTB1);
  asm("nop");
// setup ****************************************************************
  Serial.begin(19200); // open serial at 19200 bps
  pinMode(LED, OUTPUT); // set output pins
  pinMode(POWER, OUTPUT);
  digitalWrite(POWER, HIGH);  // turn on SD card
  delay(1);    // give some delay to ensure RTC and SD are initialized properly
  Wire.begin();  // initialize I2C using Wire.h library
  if(!sd.begin(SDcsPin, SPI_FULL_SPEED))  // initialize SD card on the SPI bus
 // if ('a' == 'b')
    delay(10);
    SDcardError();
    delay(10);
    //Serial.println("inside else block from setup");
    file.open(filename, O_CREAT | O_APPEND | O_WRITE);  // open file in write mode and append data to the end of file
    delay(1);
    String time = RTC.timeStamp();    // get date and time from RTC
    file.println();
    file.print("Date/Time,CO2(ppm)");    // Print header to file
    file.println();
    PrintFileTimeStamp();
    file.close();    // close file - very important
                     // give some delay by blinking status LED to wait for the file to properly close
    digitalWrite(LED, HIGH);
    delay(10);
    digitalWrite(LED, LOW);
  RTC.checkInterval(hourStart, minStart, interval); // Check if the logging interval is in secs, mins or hours
  RTC.alarm2set(dayStart, hourStart, minStart);  // Configure begin time
  RTC.alarmFlagClear();  // clear alarm flag
  chip.sleepInterruptSetup();    // setup sleep function on the ATmega328p. Power-down mode is used here
// loop ****************************************************************
  digitalWrite(POWER, LOW);
  delay(1);  // give some delay for SD card power to be low before processor sleeps to avoid it being stuck
  chip.turnOffADC();    // turn off ADC to save power
  chip.turnOffSPI();  // turn off SPI bus to save power
  //chip.turnOffWDT();  // turn off WatchDog Timer to save power (does not work for Pro Mini - only works for Uno)
  chip.turnOffBOD();    // turn off Brown-out detection to save power
  chip.goodNight();    // put processor in extreme power down mode - GOODNIGHT!
                       // this function saves previous states of analog pins and sets them to LOW INPUTS
                       // average current draw on Mini Pro should now be around 0.195 mA (with both onboard LEDs taken out)
                       // Processor will only wake up with an interrupt generated from the RTC, which occurs every logging interval
  chip.turnOnADC();    // enable ADC after processor wakes up
  chip.turnOnSPI();   // turn on SPI bus once the processor wakes up
  delay(1);    // important delay to ensure SPI bus is properly activated
  //RTC.checkDST();  // check and account for Daylight Saving Time in US
  CO2ppm = GetCO2(0x68); // default address for K-30 CO2 sensor is 0x68
  delay(50); // give some delay to ensure CO2 data is properly received from sensor
  // account for dropped values
  if(CO2ppm > 0)
    _CO2ppm = CO2ppm;
  if(CO2ppm <=0)
    CO2ppm = _CO2ppm;
  if(!sd.begin(SDcsPin, SPI_FULL_SPEED))  // very important - reinitialize SD card on the SPI bus
  //if('A'=='B')
    delay(10);
    SDcardError();
    delay(10);
    file.open(filename, O_WRITE | O_AT_END);  // open file in write mode
    delay(1);
    SPCR = 0;  // reset SPI control register
    file.print(time);
    file.print(",");
    file.print(CO2ppm);  // print temperature upto 3 decimal places
    file.println();
    delay(10);
  RTC.setNextAlarm();      //set next alarm before sleeping
  delay(1);
// Get CO2 concentration ****************************************************************
int GetCO2(int address)
  byte recieved[4] = {0,0,0,0}; // create an array to store bytes received from sensor
  Wire.beginTransmission(address);
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  Wire.endTransmission();
  delay(20); // give delay to ensure transmission is complete
  Wire.requestFrom(address,4);
  delay(10);
  byte i=0;
  while(Wire.available())
    recieved = Wire.read();
    i++;
  byte checkSum = recieved[0] + recieved[1] + recieved[2];
  CO2ppm = (recieved[1] << 8) + recieved[2];
  if(checkSum == recieved[3])
    return CO2ppm;
    return -1;
// file timestamps ****************************************************************
void PrintFileTimeStamp() // Print timestamps to data file. Format: year, month, day, hour, min, sec
  file.timestamp(T_WRITE, RTC.year, RTC.month, RTC.day, RTC.hour, RTC.minute, RTC.second);    // edit date modified
  file.timestamp(T_ACCESS, RTC.year, RTC.month, RTC.day, RTC.hour, RTC.minute, RTC.second);    // edit date accessed
// SD card Error response ****************************************************************
void SDcardError()
    Serial.print("SD Card Error");
    for(int i=0;i<3;i++)   // blink LED 3 times to indicate SD card write error
      delay(50);
      delay(150);
Delta_G
In this hobby, reading directions and documentation first is a crucial must.
How to use this forum - please read
Please post your code like it says to if you want answers.   Right now half your code is in itallics.  If you'd bothered to read the instructions that wouldn't happen to you.
In this hobby following instructions is a crucial must:
Quote
And are you sure it is formatted the right way?
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Nick_Pyner
Well, it looks like he's gotten off to a really great start then. No point in looking at anything else.....
