Topic: Will starting current burn everything ? (Read 423 times) previous topic - next topic
xixigogo
Jun 12, 2018, 11:49 am Last Edit: Jun 13, 2018, 12:01 pm by xixigogo
Hi all,
Beginner's question..
I'm trying to creat a motion simulator. Using IBT_2 (43A) as the motor driver.
Connections are showed in attached pic. It works well with a small motor.
Now I'm intended to use a 24V motor. But I got confused how the starting current and stall current affect the whole system.
The limit of IBT_2 is 43A while the starting current of the motor is 80A. If I connect the components as the structure in the pic, will I burn everything ?
I tried to dig deeper. However more deeper, more confused. :smiley-cry:
My power supply is 24V/20A/480W, is it enough to power my motor?
Can anyone explain to me please? or give me some clues. Thanks a lot.
MarkT
If that diagram is accurate then the switchmode 24V PSU likely won't manage 80A, I doubt you have to worry about such high currents, but you will have to worry about the behaviour of the supply on over-current - if it shuts down then that's a problem.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
xixigogo
Thanks for your help!
Would it help if I use two motor drivers in parallel to ensure more current ?
And yes, I'm using a 24V power supply (480W). Any advice for avoiding this shut down situation or I should just replace it with a larger power supply ?
TomGeorge
Everything runs on smoke, let the smoke out, it stops running....
