Topic: Syncing Problem with two singnals (Read 405 times) previous topic - next topic
Crameroni
Hello
Does anybody have an idea, why the two signals are starting at different points of time?
I want them to start at the same time, but stay on for seperate times.
I attached a screenshot from my oscilloscope.
It looks like the case of setting the pin low is synchron but I want them to start high synchronous.
Thanks for your answers.
Crameroni
Quote
int VVRPin =  22;      // the number of the VVR pin
int VDRPin = 23;       // the number of the VDR PIN
int VVRState = LOW;     // VVRState used to set the VVR
int VDRState = LOW;    // VDRState used to set the VDR
unsigned long previousVVRMillis = 0;        // will store last time VVR was updated
unsigned long previousVDRMillis = 0;       // will store last time VDR was updated
long VVROnTime = 25;          // milliseconds of on-time VVR
long VVROffTime = 1970;       // milliseconds of off-time VVR
long VDROnTime = 210;         // milliseconds of on-time VDR
long VDROffTime = 1785;       // milliseconds of off-time VDR
  // set the digital pin as output:
  pinMode(VVRPin, OUTPUT);
  pinMode(VDRPin, OUTPUT);
  if ((VVRState == HIGH) && (currentMillis - previousVVRMillis >= VVROnTime))
    VVRState = LOW;  // Turn it off
    previousVVRMillis = currentMillis;  // Remember the time
    digitalWrite(VVRPin, VVRState);  // Update the actual VVR
  else if ((VVRState == LOW) && (currentMillis - previousVVRMillis >= VVROffTime))
    VVRState = HIGH;  // turn it on
  if ((VDRState == HIGH) && (currentMillis - previousVDRMillis >= VDROnTime))
    VDRState = LOW;  // Turn it off
    previousVDRMillis = currentMillis;  // Remember the time
    digitalWrite(VDRPin, VDRState);  // Update the actual VVR
  else if ((VDRState == LOW) && (currentMillis - previousVDRMillis >= VDROffTime))
    VDRState = HIGH;  // turn it on
weird_dave
You are starting with both on states low, they are low for different lengths of time, so they go high at different times the first time round and continue from there. The reason they look synced on the falling edge is simply because your total times are the same, so they drop together.
