Topic: Using Arduino as a DSP phase shifter (Read 227 times) previous topic - next topic
akmetal
Is it possible to use an Arduino as an active phase shifter.  Where the analog circuit takes in a signal from the enviornment and then shifts is prescribed amount and converts the new signal back to analog?
See attached circuit below.
I am hoping the triangle wave generator will give me spread spectrum across a range of frequencies rather than just a single frequency.
Thank you
MrMark
One could implement an phase shifter at audio frequencies in Arduino.  It has no chance at the UHF radio frequencies your block diagram suggests.
akmetal
