Topic: Rotary encoder missing pulses (Read 1 time) previous topic - next topic
Maxxheadroom
Hello everybody,
 I have been working on this project for a while now, I am getting quite close but I am having an issue with my encoder, it seems if I rotate my encode at anything other than quite slow it misses pulses. I thought initially this was bouncing however with my count remaining consistently low it would appear it is simply missing pulses. If I rotate the encoder slowly, say around 15 RPM there are no issues and I get a consistent number however much about that and my numbers begin to drop. I am hoping you guys can give me some insight as to what might be going on here... This is the encoder in question...
https://www.amazon.com/gp/product/B06XQTHDRR/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Code: [Select]
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f, 20, 4); // set the LCD
//address to 0x3f for a 16 chars and 2 line display
const int clkPin = 3; //the clk attach to pin2
const int dtPin = 2; //the dt attach to pin3
const int swPin = 4 ; //the number of the button
int encoderVal = 0;//raw counts from encoder
const float distancePerCount = 1 ; //adjust as required
float totalDistance = 0.0;
//added variable for interrupt handler
volatile int count = 0;
  lcd.init();  // initialize the lcd
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Belt Length :");
  //set clkPin,dePin,swPin as INPUT
  pinMode(clkPin, INPUT_PULLUP);
  pinMode(dtPin, INPUT_PULLUP);
  pinMode(swPin, INPUT);
  digitalWrite(swPin, HIGH);
  Serial.begin(9600); // initialize serial communications at 9600 bps
  attachInterrupt(digitalPinToInterrupt(clkPin), isrA, CHANGE);
  attachInterrupt(digitalPinToInterrupt(dtPin), isrB, CHANGE);
  int change = getEncoderTurn();
  if (change != 0)
    encoderVal = encoderVal + change;
    totalDistance = encoderVal * distancePerCount;
    Serial.println(encoderVal); //print the encoderVal on the serial monitor
    Serial.println(totalDistance, 2); //print float with 2 dp
    lcd.setCursor(5, 1);
    //lcd.print(encoderVal);
    lcd.print(totalDistance, 2);
  if (digitalRead(swPin) == LOW) //if button pull down
    //encoderVal = .157;
    encoderVal = 0;
    lcd.clear();
int getEncoderTurn(void)
  noInterrupts();
  int result = count;
  count = 0;//reset count
  interrupts();
  return result;
void isrA() {
  if (digitalRead(dtPin) != digitalRead(clkPin)) {
    count ++;
    count --;
void isrB() {
  if (digitalRead(clkPin) == digitalRead(dtPin)) {
    count ++;
    count --;
Southpark
#1
Jun 13, 2018, 08:51 pm Last Edit: Jun 13, 2018, 09:53 pm by Southpark
Maybe you could start with trying the mode "FALLING" for the attachInterrupt .... for testing.
And whenever an interrupt occurs, you could add 1 count.
Do this with a new piece of code that contains bare minimum code..... just enough for testing. And you can use serial monitor to display the result of the counts.
ReverseEMF
#2
Jun 13, 2018, 09:03 pm Last Edit: Jun 13, 2018, 09:27 pm by ReverseEMF
Well...several things:
  • I see a couple of resistors in one of the photos.  Presumably those are pull-ups [or even pull-downs?!?].  It would be great if you used a meter, or something, to find out.
  • If they are pull-ups, then use INPUT instead of INPUT_PULLUP on the CLK and DT pins BUT one of the pins [CLK/DT/SW] seems to be missing a resistor, so you will need to determine which ones are involved.
  • If they are pull-downs, then using INPUT_PULLUP could very well, be your problem, as the pull-down resistor will working with the MCU pull-up, to form a voltage divider, and since 10k [the apparent value of the resistors on the Encoder board] is around 1/2 or more [much more] of the value of the MCU internal pull-up, the voltage will never rise high enough to register a HIGH -- ever]
  • There should be a third resistor.  But, based on the photo, only R2 & R3 are populated.  R1 appears to be nothing more than an "air resistor".
  • A schematic of your setup would sure help.  And, perhaps, a photo, or three.
  • If you have a scope, a two channel "printout" of the waveforms generated by a couple of turns, would be gold!
I suppose I can see how a quadrature output could be interpreted as a "Clock" and "Data" signal, but which one is which, is arbitrary, so it makes me wonder if something else is going on!?!
BTW: Here's a good article on how an encoder works, and how ot  [at least, the typical encoder]: https://www.allaboutcircuits.com/projects/how-to-use-a-rotary-encoder-in-a-mcu-based-project
"It's a big galaxy, Mr. Scott"
Please DON'T Private Message to me, what should be part of the Public Conversation -- especially if it's to correct a mistake, or contradict a statement!  Let it ALL hang out!!
cattledog
I can find nothing wrong with your code when used with an optical encoder turned quite fast. It does not appear to miss any counts.
I have one suggestion. Verify that there are indeed 10K pull up resistors to 5v on the back of your board.
If they are not there, then use a stronger external pullups to 10K or 4.7K or 2.2K in stead of the internal resistors used by the INPUT_PULLUP mode.
Even with the 10K resistors on the board, stronger pullups might help.
I would really question the use of Keyes 040 mechanical encoder for fast rotation. I am surprised that it wont go faster than 15 rpm, but they are cheaply made, and the internal switches may not work properly at higher speeds. They are best used for manual input of menu selection and things like that.
If you are really trying to monitor a motor at higher than 15 rpm I would consider an optical or magnetic encoder.
Maxxheadroom
#4
Jun 14, 2018, 07:28 pm Last Edit: Jun 14, 2018, 07:43 pm by Maxxheadroom
Thanks for the input guys, I have verified the 10k resistors are in fact in place, and pull up to 5v. I changed the INPUT_PULLUP to just INPUT with identicle results. The encoder is mounted in the center of a pulley, it does not need to spin extremely high RPM but certainly higher than 15. This machine will be used to measure out lengths of belt, the belt is pulled across the pulley and through a sheer by hand I would think 100 RPM would not be an unreasonable speed to see on this encoder. I've attached a few pictures of my setup. It is a bit of a mess as I have it torn apart at the moment trying to figure this out.
jremington
I agree with cattledog. That encoder is intended for manual operation only, and will wear out quickly if machine driven.
ReverseEMF
#6
Jun 14, 2018, 08:59 pm Last Edit: Jun 14, 2018, 09:00 pm by ReverseEMF
OK, some of you might have noticed that I removed a previous post.  I did that because I wired up a test, using an algorithm that I had used decades ago.  It was an algorithm that worked well, then, but was exhibiting the same issues as the OP was seeing, in my test setup.
So, I dug in and did a bunch of research, and tried various algorithms, watched the waveforms on my scope, and came up with the following (which I am sharing, even though it's not advised that the OP use the encoder eluded to, this code should work for the right kind of quadrature encoder [such as an optical encoder]):
This code works VERY well, even when I spin the encoder pretty fast.  If I spin it as fast as I can, i.e. I flick it with my fingers, it tends to not update the count, but there are no other glitches -- in other words, it resumes the count where it was before the inactivity.  It doesn't jump around at all.  BTW: that was with the debounce delay active.  If I turn the debounce delay off, it might be responding a little faster, but it also, increments when it should decrement, and vice versa.
The basic premise in decoding an encoder, is: Direction is determined by which switch changes first.  CW or CCW depends on which encoder switch is defined as "A" and which is "B", so it's arbitrary, but to make the language easier, I will assume that when switch "A" changes first, that is CW and when switch "B" changes first, that's CCW.  Then, a Full Action is determined by the other switch changing.  To distinguish between these two "modes", one looks at whether the switches are in the same state, or in opposite states.  At rest, the switches will be at the same state [i.e. either both open or both closed].  When rotating between the detents, there will be a point where the switches are at different states [i.e. one open and one closed].  When a rotation begins, the switch that first changes state, determines the direction of rotation.  Then, when the other switch changes state, that indicates a full rotation and that it's time to increment or decrement the count [or whatever action is intended, when rotating the encoder].
Software debounce is achieved by catching unexpected states, as can be seen in the demo code, below.
BTW: the encoder I used may be different than the one the OP indicated.
I'll post the code in a new reply, since including it here exceeds the 9000 character limit!
ReverseEMF
#7
Jun 14, 2018, 08:59 pm Last Edit: Jun 14, 2018, 11:55 pm by ReverseEMF
UPDATE: I remembered that the delay() function doesn't function in an Interrupt Routine, so I changed it to delayMicroseconds().
Here's the altered code:
Code: [Select]
 *                                Encoder Demo
 * Demos a rotary encoder of the kind where it's two switches are at the same
 * state at rest [i.e. when shaft is not turning], and are at different states
 * when between detents. From one detent to another, one switch transitions,
 * at which point the two switches are in opposite states, then the other
 * switch transitions, and the two switches are at the same state.  For example:
 *          A  |  B
 * Rest 1:  O  |  O
 * Trans 1: C  |  O
 * Rest 2:  C  |  C
 * Trans 2: O  |  C
 * Rest 3:  O  |  O
 * Where 'O' = Open  &  'C' = Closed
 * This demo increments in one direction, until a MAX_COUNT is reached,
 * then stays at that MAX_COUNT.  When rotated in the other direction, the count
 * decrements until it reaches zero, where it stays until rotated the other way.
 * Also, because it's hard to see glitchs in numbers [at least for some of us ;)]
 * I added a "graph".  Basically it's visual feedback, and makes glitches VERY
 * easy to see.
 * Note: I watched the switch transitions on a scope, and saw no switch bounce
 *       until I turned the encoder shaft REALLY fast.  In all other cases,
 *       it was VERY clean (though there must be the occasional bounce, because
 *       of the glitches that occur when the debounce delay is disabled)!  Not all
 *       encoders may be that clean, and perhaps, as rotary encoders ages, this
 *       might get worse -- stress testing might be prudent.
 * Version 04: Minimal code in the Interrupt Handlers.  Works Great!!  Only VERY
 *             occasional glitches when the debounce delay is not activated, otherwise
 *             I was unable to get it to glitch, even with manic rotation!
#define NO_EXT_PULLUPS          false
#define INCLUDE_DEBOUNCE_DELAY  true
//                Pin Defines
#define PIN_ENCODER_A 2
#define PIN_ENCODER_B 3
#define PIN_ENCODER_PB 4
//                Constants
const byte ENC_DIR_UNKNOWN   = 0;
const byte ENC_DIR_CW        = 1;
const byte ENC_DIR_CCW       = 2;
const int MAX_COUNT          = 60;
const int MIN_COUNT          = 0;
#if INCLUDE_DEBOUNCE_DELAY
const unsigned long DDELAY   = 200;   // Number of uS for Debounce Delay
#endif
//                Parameters
byte encoder_direction             = ENC_DIR_UNKNOWN;
volatile boolean encoder_changed_A = false;
volatile boolean encoder_changed_B = false;
boolean count_changed              = false;     // So the Serial port is not flooded with useless information
int da_count                       = MIN_COUNT;
String graph                       = String(MAX_COUNT+1);
String buf;
//                Function Prototypes
inline void update_count(int inc_or_dec);
//                Interrupt Service Routines
void ISR_Encoder_A()
  delayMicroseconds(DDELAY);        // Debounce delay [without this, there are [very] occasional glitches]
#endif
  encoder_changed_B = false;        // Just in case things go wonky
  encoder_changed_A = true;
void ISR_Encoder_B()
#endif
  encoder_changed_A = false;        // Just in case things go wonky
  encoder_changed_B = true;
//                         SETUP
  Serial.begin(115200);      // Be sure to either change this to 9600, or change the setting on your terminal
#if NO_EXT_PULLUPS
  pinMode(PIN_ENCODER_A, INPUT_PULLUP);
  pinMode(PIN_ENCODER_B, INPUT_PULLUP);
#endif
  pinMode(PIN_ENCODER_PB, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(PIN_ENCODER_A), ISR_Encoder_A, CHANGE);
  attachInterrupt(digitalPinToInterrupt(PIN_ENCODER_B), ISR_Encoder_B, CHANGE);
  Serial.println("Welcome to the Encoder Test Sketch!");
  // Fill graph string
  graph = "";
  for (int glen=0; glen<MAX_COUNT; ++glen)
    graph += "*";
//                         LOOP
  // Test the Encoder Push Button
  if (digitalRead(PIN_ENCODER_PB) == LOW)
    // Your Push Button code here
  if (encoder_changed_A)
    if (digitalRead(PIN_ENCODER_A) != digitalRead(PIN_ENCODER_B))     // A != B
      // Then the rotation is in the first stage, and we now know that A changed first.
      // Thus this is a Clockwise rotation.
      if (encoder_direction != ENC_DIR_CW)
        // This is where rotation direction is determined
        encoder_direction = ENC_DIR_CW;
      else if (encoder_direction == ENC_DIR_CW)
        // This is either a bounce, OR the shaft rotation reversed before the B switched
        // changed, so cancel any direction detection
        // ERROR!!  Mark the direction as Unknown so we don't get a false action!
    else    // A == B
      if (encoder_direction == ENC_DIR_CCW)
        // Then, this is the second half of a rotation.  Set the encoder direction to
        // unknown to set this up for the next rotation action.
        // And, because this is a CCW rotation, decrement the count.
        update_count(-1);
        // ERROR!!
  else if (encoder_changed_B)
    if (digitalRead(PIN_ENCODER_B) != digitalRead(PIN_ENCODER_A))     // A != B
      if (encoder_direction != ENC_DIR_CCW)
        encoder_direction = ENC_DIR_CCW;
      else if (encoder_direction == ENC_DIR_CCW)
        // B switched changed, so cancel any direction detection
        // ERROR!!
    else     // A == B
        update_count(1);
        // ERROR!!
  // Provide feedback regarding the current encoder count and only update it
  // When the count has changed -- so there isn't a deluge of Serial data.
  if (count_changed)
    Serial.print("Count: ");
    // Force the number colum to a consistant width of 2, so the graph has
    // consistant positioning.
    if (String(da_count, DEC).length() == 1)
      Serial.print(" " + String(da_count, DEC));
      Serial.print(da_count);
    Serial.print(" ");
    Serial.println(graph.substring(0, da_count));
//                 Function Defnintions
  da_count += inc_or_dec;
  if (da_count > MAX_COUNT)
    // Pin the count at the Maximum Count
    da_count = MAX_COUNT;
  if (da_count < MIN_COUNT)
    // Pin the count at the Minimum Count
  // This is meant to be used to limit Serial output.
  count_changed = true;
Southpark
#8
Jun 14, 2018, 09:58 pm Last Edit: Jun 14, 2018, 10:02 pm by Southpark
I agree. Grab an optical quadrature rotary encoder for cases where the shaft is continually rotating.
ReverseEMF
#9
Jun 14, 2018, 10:01 pm Last Edit: Jun 14, 2018, 10:29 pm by ReverseEMF
BTW: Here's a link to a YouTube video that does a very good job of describing how an encoder works, and appears to feature the very encoder you are using:
https://youtu.be/v4BbSzJ-hz4
Also, based on another video I watched [very tedious, full of superfluous information, and even misleading in places, thus the reason for not including it, here], I get the impression that your encoder [the one you purchased from Amazon] rotates through 4 switch changes between detents, whereas the encoder I experimented with, only does 2 switch changes per detent.
The code that I posted should still work, but it will, likely, generate two counts per "rotation" [i.e. between each detent].  If that's not in alignment with your needs, then you could count by 0.5 (using a float, instead of an int), or still count by 1, but divide the count by 2 [shift right by one], before using it, or count only when both switches are open, or vice versa [determined by what the rest state is -- i.e. if the rest state is, both switches open, then only count when a rotation brings the encoder back to the both-switches-open state.].
ReverseEMF
I agree. Grab an optical encoder for cases where the shaft is continually rotating.
Or magnetic, with a Hall Effect device [digital output being the, likely, best choice].
Southpark
Agreed. That's a good variety to use.
ReverseEMF
#12
Jun 14, 2018, 11:17 pm Last Edit: Jun 14, 2018, 11:57 pm by ReverseEMF
Here's a rework of my Rotary Encoder Demo, but with most of the Encoder code in the Interrupt Routines (so the loop() func is cleaner).  It still exhibits the occasional glitch [but only when the shaft is spun and released, like a top--so it's left to come to a stop on it's own, rather than being under muscle control the whole time--probably some vibration that isn't being dampened by finger mass], but only by +/- 1 count:
Code: [Select]
 *                           Rotary Encoder Demo
 *          A  |  B
 * Rest 1:  O  |  O
 * Trans 1: C  |  O
 * Rest 2:  C  |  C
 * Trans 2: O  |  C
 * Rest 3:  O  |  O
 * easy to see.
 * Version 06: Most code in the Interrupt Handlers, except the update_count() func
 *             call.  Works Great when debounce delay is active [only 200uS]!
 *             Almost as good as Version 04 with debounce delay.  Very occational
 *             glitches, though.  But only +/- 1 count.
 *             But, if I rotate at a "resonable" rate, it's pretty clean.
 *             This version is working much better than Version 05,
 *             especially with the debounce delay activated.  But, Version 04 is
 *             still the winner--by a slight margin!
//                Pin Defines
//                Constants
#endif
//                Parameters
volatile byte encoder_direction    = ENC_DIR_UNKNOWN;
volatile int inc_dec               = 0;              // This serves both to modify the count AND to serve as an indication of a count change
inline void update_count();
  delayMicroseconds(DDELAY);        // Debounce delay [without this, there is a slightly greater incidence of [very] infrequent, +/- 1 count glitches]
#endif
      // This is either a bounce, OR the shaft rotation reversed before the B switch changed, so
      // cancel any direction detection.
      // ERROR!!
  else    // A == B
      inc_dec = -1;
      // ERROR!!
#endif
      // changed, so cancel any direction detection.
      // ERROR!!
  else    // A == B
      inc_dec = 1;
      // ERROR!!
//                         SETUP
#if NO_EXT_PULLUPS
#endif
  graph = "";
    graph += "*";
//                         LOOP
  // When the count has changed [either 1 or -1 -- if 0, it's ignored] -- so
  // there isn't a deluge of Serial data.
  if (inc_dec != 0)
    update_count();
    Serial.print(" ");
  da_count += inc_dec;
  inc_dec = 0;  // So no more counting will occur until this is changed to either 1 or -1
ReverseEMF
#13
Jun 15, 2018, 12:38 am Last Edit: Jun 15, 2018, 12:40 am by ReverseEMF
And, here's a bit of pseudo code that may make this a bit more clear:
Code: [Select]
MODULE 1
  if (A != B)
    result = 0
    if (A changed)
      direction = CW
    else if (B changed)
      direction = CCW
      Ignore this condition
  if (A == B)
    if (direction == CW  AND  B changed)
      direction = NONE  // So this triggers no more for this round
      result = 1
    else if (direction == CCW  AND  A changed)
      result = -1
      We're probably at rest so ignore
MODULE 2
  Use _result_ in some way
emir22
I too had this problem .that when i was turning more fast .then arduino was droping the singnals and couldnt count correctly .i gave up that war and focus to lineer position resistance method  :smiley-confuse:
