Topic: Flash page is locked (Read 473 times) previous topic - next topic
davideIO
Hello,
I could not upload to Arduino DUE anymore.
The error message is:
Code: [Select]
[                              ] 0% (0/96 pages)
An error occurred while uploading the sketch
I found similar issues by googling but no real solution.
I'm using the programming port of the DUE. Up to now 2 boards have been blocked in a way I really don't understand.
Anyone has a solution or a workaround?
ard_newbie
davideIO
Yes I'm using DueFlashStorage. Is it bad idea?
ard_newbie
The issue solved in the thread I indicated above was observed after the OP used DueFlashStorage library.
davideIO
#4
Jun 21, 2018, 10:23 am Last Edit: Jun 21, 2018, 10:28 am by davideIO
Ok, I'll check it.
But it's strange. I've been using the DueFlashStorage for 2 years or more and it's the first time I'm facing this issue.
Anyway. Thank you for quick help.
Regards
