Topic: Rainbowduino mega 2560 i2c problem. Neorainbowduino (Read 2394 times) previous topic - next topic
shtonkalot
Hello all.
I'm very new to the world of arduino and have gotten myself an Arduino mega 2560 as well as a rainbowduino and rgb matrix.
I am running the neorainbow firmware on both devices and am trying to communicate with the examples in the firmware package.
I have edited the wire libraries as stated here: http://www.neophob.com/2010/07/rainbowduino-fun-aka-neorainbowduino
And I hooked up everything so it appears correct.
When I run the 12c scanner it finds my rainbowduino!
When I load the simple example it runs showing random pixels on the matrix but I get some errors after a while as follows:
Code: [Select]
com.neophob.lib.rainbowduino.Rainbowduino waitForAck
INFO: No serial reply, duration: 30ms
When I run the invader example I get no display but the sketch runs without error in processing.
Anyone got any ideas? I've been scratching my head for over a week on this one.
I was wondering if there are any notable differences in the way a mega 2560 handles i2c compared to other arduinos. I know the pinout is different but is that all?
WillR
#1
Mar 16, 2011, 04:17 pm Last Edit: Mar 16, 2011, 04:19 pm by WillR Reason: 1
Power issues?
How are you powering all of this? Not off the Arduino I hope.
I have a Mega2560 and the I2C interface seems to work fine -- even with OneWire.
shtonkalot
Quote
Power issues?
Shouldn't be. I'm running the rainbowduino off a 8.5v input.
I have the pins (sda, sdl, gnd, reset) hooked up from the arduino to the rainbowduino.
