Topic: Converting 8VAC to 5VDC (Read 2637 times) previous topic - next topic
sshaikh
Jul 02, 2018, 12:48 am Last Edit: Jul 02, 2018, 12:50 am by sshaikh
For a smart doorbell project, I'm considering using a uninterrupted 8VAC supply to provide power to a SoC module and some relays.
A quick google came up with this:
https://www.ebay.co.uk/itm/L7805-AC-DC-DC-Step-down-Regulator-Power-Supply-Module-7V-36VDC-6-27VAC-to-5VDC/232022503091
Which seems to do the trick, but uses an L7805. Is this the best way to achieve what I need? I ask because I read that it's pretty inefficient. As an alternative I also spotted this:
https://www.ebay.co.uk/itm/AC-DC-Buck-Step-down-Voltage-Converter-3-3V-5V-6V-9V-12V-Rectifier-Filter-Module/253333543363
But partly as a learning exercise, I'm wondering if I can do better by building my own, based on this:
https://electronics.stackexchange.com/questions/97571/how-to-convert-6v-ac-to-5v-dc
However I'm having some difficulty working out what I'll need.
At 8VAC, the resulting DC will be 8 x 1.414 ~ 11.31 - 1.4 ~10v. I was hoping to just use a buck after this point like this:
https://www.ebay.co.uk/itm/DC-Buck-Step-down-Adjustable-Voltage-Regulator-Module-5v-24v-to-1-8v-3-3v-12v-3A/273157036523
But do I still need the various capacitors? If so, how can I work out which ones?
Also can I use 1N4148 for the rectifier bridge?
allanhurst
#1
Jul 02, 2018, 01:08 am Last Edit: Jul 02, 2018, 01:13 am by allanhurst
A simple bridge rectifier, storage capacitor  and linear regulator would work OK.
If you want higher efficiency a buck convertor is better, but a 'lashup' on a breadboard will almost certainly not work - the devices involve very fast high current switching and need a carefully designed PCB.
You can buy such premade devices capable of up to an amp or so at 5v very cheaply (~£1 ) on eg eBay, and I suggest you go that way.
You'd still need a rectifier and storage capacitor, of course
Allan
wvmarle
Based on your other thread all you want to power is an Arduino so you don't need much current. This 1A buck converter seems to be the ideal solution: plug and play.
If you want to experiment:
Bridge rectifier, gives you a 100 Hz half-sine voltage. Add a big cap (that module you linked to uses a 1000 uF cap) on the output to smooth it, then a linear regulator like indeed the good old 7805 with its own caps (330nF ceramic both sides iirc - check data sheet). That should also give you a rather clean supply.
Such a linear regulator may need a small heat sink; 200 mA is typical for an Uno so that's 0.2 * 5 = 1W of power dissipated.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
ReverseEMF
#3
Jul 02, 2018, 07:10 am Last Edit: Jul 02, 2018, 07:16 am by ReverseEMF
Not sure what you mean by an "SoC module", but if it's anything like the typical Arduino [this is an Arduino forum, after all], then it probably has a built in, voltage regulator [could be Linear and it could be a Switch Mode Buck Converter].
So, you may be able to get away with rectifying and filtering that 8VAC with a Bridge Rectifier arrangement, and filter capacitor, like in that first link of yours [sans 7805], and just use the Arduino's regulator.  Can't advise you further, because you didn't divulge what device you're using.
BUT, it depends on how much current that 8VAC transformer can put out, and what the over all current requirement will be for everything you want to drive [e.g. relays and such].  Also, transformers are notorious for having a higher open circuit voltage than the rated voltage [i.e. the rated voltage is at the rated current].  So, your 8VAC transformer might run at 8VAC when it's ringing the bell, but when the bell isn't ringing, that voltage could be more like 11VA, or more!
Also, if your application doesn't require much current, then why even be concerned about efficiency?  I mean if we're talking about a different of fractions of a penny [assuming your using US currency wherever you are ;)], then what's the fuss?
You might get away with using 1N4148s, but being a beginner, I suggest not adding another failure mode variable and use 1N4004s [or 1N4005 or 1N4006 or 1N4007].
Well, it's late...so more tomorrow...unless someone else wants to take over :D
"It's a big galaxy, Mr. Scott"
Please DON'T Private Message to me, what should be part of the Public Conversation -- especially if it's to correct a mistake, or contradict a statement!  Let it ALL hang out!!
sshaikh
#4
Jul 02, 2018, 03:23 pm Last Edit: Jul 02, 2018, 03:30 pm by sshaikh
Thank you for all the replies. To answer some of the questions:
I have a habit of wanting to "do things right", but also learn along the way. Although this has gotten me deep into many rabbit holes, I suppose part of my question is why I would want to use a regulator over a buck or vice versa. Hence although it might not make a difference in practical terms, having something that's as efficient as can be would make me feel warm and tingly inside.
I said "SoC module" because I'm still not sure what I'll be using - I'll probably settle on a Wemos D32, but it might be a D1 Mini Pro instead. I actually had a look at the schematics and I think they all use a ME6211 which operates on a voltage range of 2-6v which sounds too narrow for a rectified 8vac? Also looking around I can expect these to draw around 800mA peak since they'll be using the wifi a bit.
For context here's the current bell:
I've pulled out the multimeter and have found the following for the transformer:
  • The transformer idles at 9V
  • It's a DAT03A which is rated at 2A
  • When the button is pressed the voltage drops to 8.7V.
And for the chimes:
  • The label of the chime says AC 8V ~ 1A
  • The resistance across the AC chime terminals (I tested both also while button was pressed which I assumed shouldn't matter but did it anyway) is around 4 ohm
  • The voltage at across one of the chimes when the button is pressed is around 6.4V
  • I can't seem to measure the current with my multimeter (I later realised it only works with DC), but according to the above it draws around 1.6A (6.4v/4ohm), which sounds pretty high.
So unless my schoolboy testing is in error, it sounds like the transformer shouldn't be able to provide enough current for the two chimes let alone the wemos/relays. Am I missing anything?
allanhurst
#5
Jul 02, 2018, 04:53 pm Last Edit: Jul 02, 2018, 05:32 pm by allanhurst
Yes.
The supply is AC, so the impedance it sees in the chime  depends both on it's dc resistance  and it's inductance. I'll assume the AC is a pure sinewave.
- ie R and  2*pi* F * L.
Where R is the dc resistance in ohms , F is the frequency of the supply, and L is the inductance in Henries.
I'll call this second ezpression ZL.  The complex impedance of the inductive part.Still measured in ohms.... but.
You can't just add these quantities as you would with series resistors , since the current in the inductor has a phase advance of 90 degrees .
The actual expression for the addition is:
  Z ( the complex impedance of the R and L in series ) =  R + j ZL where j is SQRT(-1).
So you have to add them as two orthogonal vectors - ie
|Z| ( the magnitude of the complex impedance) =  SQRT( R^2 + ZL^2))
You can then apply ohms law : I = V/|Z|
The phase angle of the current flowing compared to the applied ac voltage is given by
 arctan ( ZL / R )
Allan
MarkT
The bell is operated by electromagnet, basically a big inductor, current is dominated by the inductance, not
the DC resistance.   Apply 8Vdc to the thing and it will carry much larger current and then overheat
and fry itself.
sshaikh
Thank you both for the responses. Interestingly I can connect a 9V battery to it but I suppose something else is going on there.
So if our conclusions are correct, does that mean I'm on a fool's errand trying to tap into the 8VAC? My circuit will sit next to the transformer so I will have access to 240v too and so could use a USB wall wart for my 5v.
It just feels like I'm giving up too easily ;)
ReverseEMF
#8
Jul 02, 2018, 08:30 pm Last Edit: Jul 02, 2018, 08:36 pm by ReverseEMF
... I suppose part of my question is why I would want to use a regulator over a buck or vice versa. Hence although it might not make a difference in practical terms, having something that's as efficient as can be would make me feel warm and tingly inside.
Well, there is what you might want vs what might be an industry practice, or the practice of most of the rest of us  ;)
If you want warm-and-fuzzy efficiency, then by all means, use a Buck Converter.  But, generally, and this is somewhat subjective, if the current demand is less than 200 mA or so, then a Linear solution probably makes more sense.
BUT, if the current demand is, as you say, in the 800mA range, then a Switch Mode solution makes more sense.
Well, this is an Arduino forum, so I'm sure you'll forgive the fact that I have no experience with any of the platforms you mentioned.
Not at all.  8VAC will easily accommodate that voltage range, as long as the 8VAC source can supply the required current.  But, of course, a regulator will be required.
What you tested is the DC resistance.  AC resistance, or reactance is the quantity in play.  That 100Ω on the label is, likely, the AC resistance at 50 or 60 Hz [depending on your locale].  8V/100Ω = 800mA which is in the vicinity of 1A.  AND, actually, the actual resistive quantity in question, here, is Impedance, which is a Vector summation of both pure resistance and inductive reactance.  And, one would expect that 100Ω assessment to be the impedance.
My knowledge of AC is a bit rusty and my knowledge of electromechanical math and physics is just plain lacking, so I have no explanation for the 200mA disparity between the 1A rating and the 800mA math result.
Sounds like a lot of voltage is being dropped in the wires.  A smaller gauge [fatter wire] will fix that.
...but according to the above it draws around 1.6A (6.4v/4ohm), which sounds pretty high.
Yup -- 'cuz you're dealing with AC, not DC.
So, each bell has a 1A rating on the label [perhaps that's the maximum recommended current], an apparent actual 800mA current demand at 8VAC, and you're running two bells off a transformer rated at 2A max.  That doesn't leave much room for an SoC module demanding peaks of 800mA.  Though you can get a bit of relief using a Switch Mode DC-to-DC converter [SMC]:
If the SoC runs at 3.3V [most with WiFi, do], then if, say, the SMC has an efficiency of 85% [conservative], then:
ViIi = eVoIo   where:   Vi & Ii are the input voltage and current, Vo & Io are the output voltage and current, and e is the efficiency.
Vi = VAC√2 - 1.4    where: VAC is the the AC voltage of the bell transformer and 1.4 is the bridge rectifier forward voltage drop
thus
Ii = eVoIo / (VAC√2 - 1.4)= .85(3.3)800mA / [8.7(1.414) - 1.4] = 206mA
So, 0.80A*2 + 0.2A = 1.8A  or  200mA shy of the max of 2A
This is the magic of power transfer!
Note: these calculations are based on a nominal current of 800mA, but with your present setup, that doesn't seem to be the reality.  If there is only around 6.4V at the bell, then that's more like a current of 640mA.  You do the math ;)
sshaikh
#9
Jul 02, 2018, 11:33 pm Last Edit: Jul 02, 2018, 11:35 pm by sshaikh
Eeek. That 100Ω is an artifact of the circuit drawing app I used - it was the default and has no basis in reality and my focus at the time was to draw up the circuit. So my lesson learned here is to never be flippant when providing these diagrams. That said, I don't think it changes the conclusions too much so thank you.
Quote
Can you elaborate please? My understanding is that after rectifying I'll end up with 10vdc (8 x 1.414 ~ 11.31 - 1.4 ~10v). Isn't that what would be fed into the ME6211?
Thank you for the rest of the explanation. Since I have no real information about the AC resistance of the chimes or the current they draw, I'm going to be a little conservative and assume the chimes /are/ drawing 1A, which won't leave much out of the transformer. As another engineering friend told me KISS is very important when getting stuff to actually work reliably so as excited as this thread has made me I think I'm going to wuss out and just use a USB wall wart with 240vac.
#sad
allanhurst
Probably wise if you just want to get something going. But better to choose a higher voltage wallwart ( 8-15v)
and feed it into the Vin of the arduino - it's internal high quality linear regulator will take care of the rest....
Allan
wvmarle
That 9V battery - I assume a small block battery - can supply no more than 200 mA or so on a good day. It wont fry your bell or so.
I suppose what you have is the kind of bell where the attraction of the hammer to the chime also breaks the contact, causing the oscillation of the hammer and the ringing sound. That will work on both AC and DC indeed, and in AC the additional inductance effect limits the current. With your 9V battery it's the internal resistance of the battery.
That also means that you will have a very dirty power supply. Peaks every time the coil makes and breaks; almost certainly no flyback diodes either, so any power supply you connect to it has to deal with at least the voltage variations (those flyback diodes you may add yourself, don't know how and if it will affect the ringing).
As you have mains available, a USB power supply is the quick and cheap solution here.
When it comes to electrical appliances I see that rated currents are routinely overstated: if you use that amperage to calculate wattage, you often end up 20-50% higher. Or maybe that's simply peak current rating (when e.g. a fan motor just switches on) vs. average power rating.
sshaikh
#12
Jul 03, 2018, 01:40 pm Last Edit: Jul 03, 2018, 01:43 pm by sshaikh
I'm still a little confused about this.
The Ardiuno Uno seems to use this lp2985-33dbvr which takes in 16V which sounds quite handy.
However the ESP32 board I'm looking at has a ME6211 (https://wiki.wemos.cc/_media/products:d32:sch_d32_v1.0.0.pdf) which seems to take in 6v max, which I presume means the 8-15v is out?
Why would I go for a higher voltage anyway? For more options later? If it is handy to have then I can externally step down the input to 3.3v for the ESP32 (using what? A lp2985-33dbvr?).
I also need 5v to feed the relays, though, so if I stuck to the 5v looking at the schematic or board photo (https://wiki.wemos.cc/products:d32:d32) I can't tell how I would provide that 5v to the board itself - there doesn't seem to be a 5v in pin?
wvmarle
Just use a USB adapter then. 5V for the relays & the ESP32 (it'll be stepped down to 3.3V).
Paul__B
Should be OK.
Ten volts in, five out.  Wastes as much power as what it feeds, uses.  Better not to get things any hotter than you can manage to avoid.
Includes bridge rectifier, and interestingly, the cheapest of those you cited.  Looks good.  Can't see the capacitor rating but probably adequate as claimed.
Bad idea.  Very bad.  If you are referring to the switchmode design shown, such regulators are non-trivial to construct and operate stably - and you do not want it to misbehave in any fashion.  Common discussion here, best leave it to proven designs, not to mention that it is cheaper to do so.
Would work, but easier to use the one with the bridge and capacitors built in.  Note that the rectified voltage will peak at 10 V, but drop between cycles as the capacitor discharges.  However this design should have relatively low "dropout" voltage (and better than the 7805), so apart from thermal efficiency, this is an advantage of the switchmode.
Use the complete module.
Absolutely not.
That regulator is intended to regulate your 5 V supply (like USB) down to 3.3 V.  It is never intended to be supplied from 10 V.
Also looking around I can expect these to draw around 800mA peak since they'll be using the WiFi a bit.
800 mA sounds excessive, even as peak.  300 mA more likely as I recall for the ESP8266.
Door chime transformers are generally rated for intermittent use only, but the design with separate primary and secondary tends to be a sort of "choke transformer" limiting its output current.
And for the chimes:
About right - for intermittent use only.
And as others have explained, the inductance in addition, will limit the current to 1 A at 8 V.
The voltage at across one of the chimes when the button is pressed is around 6.4V[/li][/list]
Given a few more ohms in the wire.
No, add the inductance, less than 1 A.
So unless my schoolboy testing is in error, it sounds like the transformer shouldn't be able to provide enough current for the two chimes let alone the WeMOS/ relays. Am I missing anything?
Yep.  1 A each chime, two of them is 2 A, the WeMOS will not draw too much.
What sort of 9 V battery?  Did it do anything at all?
Mmmm.
It may be rated at 16 V, but without a proper heatsink, will be useless at anything above 8 V.
You provide this with 5 V - five Volts - from a regulator, such as the second, switchmode, module you cited.  It is designed for five Volts.
Not sure what you mean.
It is labelled "USB".
So, you use this regulator module to develop stable 5 V from your 8 V transformer.
Note that now, all the 8 V AC devices must be connected separate to the 5 V system, controlled by relay contacts (or SSRs with optocouplers or such).
