Topic: Send file from sd card to server (Read 5863 times) previous topic - next topic
hunter360
Hi i have esp8266 nodemcu, and sd card reader. I need send a file from sd card to server. How to do it?
i found code but it doesn't work.
here code.
Code: [Select]
    WiFiClient client;
if (client.connect("server ip", 80)) {
File file = SD.open("test.csv");
client.println(F("POST /http://example.com/...../examplefolder/ HTTP/1.1 "));
client.print(F("Host: "));
client.println("server ip");
client.println(F("Connection: close"));
client.print(F("Content-Length: "));
client.println(file.size());
client.println();
while (file.available()) {
client.write(file.read());
file.close();
client.stop();
hunter360
here code.
Code: [Select]
WiFiClient client;
client.println();
file.close();
client.stop();
PieterP
#2
Jul 03, 2018, 03:09 pm Last Edit: Jul 03, 2018, 03:13 pm by PieterP
Define "it doesn't work".
Please post your complete code. Where did you find it? What have you tried already? Do you understand the code you're using, or did you just blindly copy-paste it?
Pieter
Edit: Do not cross-post!
PaulS
Code: [Select]
Rubbish. The protocol (http://) and server are NOT part of the POST command.
Quote
How to do it?
Just like that, if you want it to take forever.
Both the read() and write() methods are overloaded to use array, resulting in many fewer packets, and much faster sending.
Juraj
#4
Jul 03, 2018, 03:15 pm Last Edit: Jul 03, 2018, 03:38 pm by Juraj
esp8266 can do client.write(file)
did you see the WiFiClient example?
PieterP
Coding Badly
hunter360
Hi, again, i am so sorry for Cross-post, but i really need help about this.
I just don't know how to send from sd card file, to server.
and when i do this...
client.write(file) -->Error compiling for board NodeMCU 1.0 (ESP-12E Module).
If you have some examples, please tell me what code i need to send from sd card to server a file.
Juraj
#8
Jul 06, 2018, 09:29 am Last Edit: Jul 06, 2018, 09:36 am by Juraj
sorry, it works only with SPIFFS file, not with SD file
the file upload is done with POST request. do not forget to set the Content-length header
Code: [Select]
WiFiClient client;
  if (client.connect(yourHost, 80)) {
    File dataFile = SD.open("filename.csv");
    client.println(F("POST /your-url HTTP/1.1"));
    client.println(yourHost);
    client.println(dataFile.size());
    client.println();
    while (dataFile.available()) {
        client.write(dataFile.read());
    dataFile.close();
    client.stop();
warning, this will be slow. if it works, we can add buffering
hunter360
Code: [Select]
  #include <ESP8266WiFi.h>
      #include <ESP8266WiFiMulti.h>
      #include <ESP8266HTTPClient.h>
#include <SPI.h>
#include <SD.h>
 ESP8266WiFiMulti WiFiMulti;
File myFile;
  WiFiMulti.addAP("ssid", "password");
        WiFiMulti.addAP("ssid2", "password2");
     Serial.println("Connecting ...");
  int i = 0;
  (WiFiMulti.run() != WL_CONNECTED) ; // Wait for the Wi-Fi to connect: scan for Wi-Fi networks, and connect to the strongest of the networks above
      Serial.println('\n');
  Serial.print("Connected to ");
  Serial.println(WiFi.SSID());              // Tell us what network we're connected to
  Serial.print("IP address:\t");
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    myFile.close();
    Serial.println("done.");
    Serial.println("error opening test.txt");
//in 00.00.000.00 is my servers ip, and in example is my url
  WiFiClient client;
  if (client.connect("00.00.000.00", 80)) {
    File myfile = SD.open("test.txt");
    client.println(F("POST /http://example.com/folder HTTP/1.1"));
    client.println("00.00.000.00");
    client.println(myfile.size());
    client.println();
    while (myfile.available()) {
        client.write(myfile.read());
    myfile.close();
    client.stop();
        WiFiMulti.addAP("ssid2", "password");
  int i = 0;
  while (!Serial) {
code works, but nothing appears in server directory.
Juraj
#10
Jul 06, 2018, 11:14 am Last Edit: Jul 06, 2018, 11:30 am by Juraj
the host and port should not be in url after POST
Code: [Select]
client.println(F("POST /folder HTTP/1.1"));
hunter360
Still nothing with changes... client.println(F("POST /folder HTTP/1.1"));
but have question, is there other way to send to server? file from sd card?
PieterP
Have you tried flushing before stopping the client?
PieterP
