Topic: Send file from sd card to server (Read 5966 times) previous topic - next topic
Juraj
how large is the file? test with a small file.
hunter360
#16
Jul 06, 2018, 01:27 pm Last Edit: Jul 06, 2018, 01:27 pm by hunter360
 it it's small file.  Only create test 1 2 3 , and nothing else.
Juraj
#17
Jul 06, 2018, 02:05 pm Last Edit: Jul 06, 2018, 02:05 pm by Juraj
use IPAddress in connect and in Host header
Code: [Select]
IPAddress serverIP(123, 456, 78, 9);
if (client.connect(serverIP, 80)) {
client.print(F("Host: "));
client.println(serverIP);
hunter360
PieterP
Time to open up Wireshark then.
Juraj
#20
Jul 06, 2018, 06:16 pm Last Edit: Jul 06, 2018, 06:19 pm by Juraj
copy to Serial the response received by the client
Code: [Select]
  while (client.connected()) {
    if (client.available()) {
      char c = client.read();
      Serial.write(c);
hunter360
Code: [Select]
      Serial.write(c);
Nothing happened....
PaulS
Quote
Of course not. Your snippet won't even compile. If you want help, you'll stop posting snippets, and start posting ALL of your code.
hunter360
#23
Jul 10, 2018, 02:09 pm Last Edit: Jul 10, 2018, 02:18 pm by hunter360
Code: [Select]
  #include <ESP8266WiFi.h>
      #include <ESP8266WiFiMulti.h>
      #include <ESP8266HTTPClient.h>
#include <SPI.h>
#include <SD.h>
 ESP8266WiFiMulti WiFiMulti;
File myFile;
WiFiMulti.addAP("ssid", "password");
        WiFiMulti.addAP("ssid2", "password2");
     Serial.println("Connecting ...");
  int i = 0;
  (WiFiMulti.run() != WL_CONNECTED) ; // Wait for the Wi-Fi to connect: scan for Wi-Fi networks, and connect to the strongest of the networks above
      Serial.println('\n');
  Serial.print("Connected to ");
  Serial.println(WiFi.SSID());              // Tell us what network we're connected to
  Serial.print("IP address:\t");
  while (!Serial) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    myFile.close();
    Serial.println("done.");
    Serial.println("error opening test.txt");
IPAddress serverIP(00, 00, 000, 00);
WiFiClient client;
      Serial.write(c);
    File myFile = SD.open("test.txt");
    client.println(F("POST /folder HTTP/1.1"));
    client.println(F("Connection: close"));
    client.print(F("Content-Length: "));
    client.println(myFile.size());
    client.println();
    while (myFile.available()) {
        client.write(myFile.read());
    myFile.close();
    client.stop();
  int i = 0;
  while (!Serial) {
Juraj
you should read the response after you send the request
hunter360
Code: [Select]
#include <SPI.h>
#include <SD.h>
File myFile;
  int i = 0;
  while (!Serial) {
  if (!SD.begin(4)) {
    return;
  if (myFile) {
    myFile.close();
WiFiClient client;
    client.println();
    myFile.close();
      Serial.write(c);
    client.stop();
  int i = 0;
  while (!Serial) {
still nothing
PaulS
That code looks like sh*t. Did you get a drunken monkey to operate the tab key for you?
Use Tools + Auto Format BEFORE you post crappy looking code like that again. Unless you don't want help. In which case, you are free to post crappy looking code.
Juraj
try it while connected to your wifi network. what is that wifimulti stuff?
hunter360
it was connected to wifi
wifimulti allowed me to set more wifi connections.
Juraj
but was it the same network where the server is?
