Topic: How to use RepRapDiscount Smart Controller (Read 15057 times) previous topic - next topic
johnwasser
The backlight LED is lighting up so I guess you have Pin 9 (Ground) and Pin 10  (Vcc) correct but the picture isn't clear enough to be sure the other six wires are correct.  Have you double-checked them against the schematic?  It appears you are using a grey wire for Ground and a black wire for +5v.
That would make the two rows:
246810
Encoder 5LCD-RSLCD-D5LCD-D7VCC
13579
BuzzerLCD-ELCD-D4LCD-D6Ground
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
Ganesh2807
#16
Jul 12, 2018, 08:38 am Last Edit: Jul 12, 2018, 09:11 am by Ganesh2807
Quote
That is encouraging.  Did you try adjusting the contrast pot again after the white boxes showed up?
@groundFungus, Thanks for your reply.
I adjust the contrast pot it will make changes in LCD display but I did not the output.
Quote
@johnwasser, Thanks for your response.
I verify the pin configuration I did not get any changes in my output.
Still I am getting this output only.
Is there any other library needed for to access this reprapdiscount smart controller?
SupraGuy
Not sure if the OP has made any progress on this in the last 3 months, but I'm interested in doing something this as well. I have a few of these controllers, and a use for them that doesn't involve 3D printing, so I have zero need for the Marlin firmware, though if need be, I CAN use a RAMPS shield to connect it. (Seems unnecessary, but I have at least 2 spare RAMPS shields as well.)
My requirements are to be able to use the 20 by 4 text output and to be able to read the rotary encoder, encoder pushbutton, and possibly the reset button. SD card write access isn't a must for this, but would be a huge bonus if I can do it.
(For those who care what the end result will be)
The idea is that I'll be using the Arduino with a couple of MAX6675 sensors to read a pair of type K thermocouples to monitor my car's exhaust gas and coolant temperature at the turbocharger, along with the output of a wideband O2 sensor, MAP sensor, and a few of the on-board ECU's diagnostic outputs for things like fuel trim compensation, injector duty cycle, vehicle speed sensor and airflow meter to get various performance metrics. If I can use the SD card slot as well, this would be used for logging the data for later analysis. If I don't get the SD card, that's fine, I can pump it out via a serial connection to a laptop for data collection.
SupraGuy
So looking at the schematics for the 2004 controller adapter and the RAMPS 1.4...
The schematics connect the pins (Assuming Arduino Mega 2560)
Code: [Select]
EXP1:
Mega    CON     Mega
37      1  2      35
17      3  4      16
23      5  6      25
27      7  8      29
GND     9 10      48
EXP2:
Mega    CON     Mega
49      1  2      NC
31      3  4      52
33      5  6      50
+5V     7  8      41
NC      9 10      NC
For whatever good it does, this will be how the controller is connected to the Arduino via the RAMPS as far as the Marlin firmware is expecting. At least in this configuration we might be able to examine the Marlin code as far as pin diagrams go.
This is probably more connection than it needs to use the display and encoder, as it also includes the connections to the SD card reader, but I do note that it only shows ground being connected to EXP1 and +5V connected to EXP2. (Well, I didn't look too closely at the functions of the other pins on the Arduino.)
Hopefully I've read the diagrams correctly.
As I had said, I'm not 100% averse to installing a sacrificial RAMPS shield for a proof of concept, but that's not a good log-term solution, and certainly not if I end up making more of them for other people.
I'm reasonably certain that this controller will produce an aestheticly pleasing and reasonably intuitive UI for what my purposes, which is one of the reasons that I'd like to use it.
svtgd
Checking to see if you had any further progress. I too am interested in a non 3d use of this controller.
danielkrah
#20
Mar 26, 2019, 09:09 pm Last Edit: Mar 26, 2019, 09:15 pm by danielkrah
I don't get were your problem is ?
All is documented ...
Code: [Select]
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  // Print a message to the LCD.
  lcd.print("1st row");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print("2nd row");
  lcd.setCursor(0, 2);
  lcd.print("3rd row");
  lcd.setCursor(0, 3);
  lcd.print("4th row");
Just connect the pins to the holes on the connector
bjean238
Witch Arduino output with connector pin?
Thanks.
MildaGenius
Thanks.
According to posted image and example:
Code: [Select]
//EXP1      Arduino
// 3        D11
// 4        D12
// 5        D5
// 6        D4
// 7        D3
// 8        D2
// 9        GND
//10        5V
This worked for me.
aggrav8d
Hi all.  Reviving this old thread because I, too, am having trouble getting mega 2560+ramps 1.4+reprap discount smart controller to work.  I'm running Arduino 1.8.9 with Windows 10.
controller is https://reprap.org/wiki/RepRapDiscount_Smart_Controller
My setup includes the adapter shield and looks like: https://imgur.com/a/SordTK9
my test is:
Code: [Select]
#define BEEPER             37
#define LCD_PINS_RS        16
#define LCD_PINS_ENABLE    17
#define LCD_PINS_D4        23
#define LCD_PINS_D5        25
#define LCD_PINS_D6        27
#define LCD_PINS_D7        29
// Encoder rotation values
#define BTN_EN1            31
#define BTN_EN2            33
#define BTN_ENC            35
// SD card settings
#define SDPOWER            -1
#define SDSS               53
#define SDCARDDETECT       49
#define KILL_PIN           41
#define LCD_HEIGHT         4
#define LCD_WIDTH          20
LiquidCrystal lcd(LCD_PINS_RS, LCD_PINS_ENABLE, LCD_PINS_D4, LCD_PINS_D5, LCD_PINS_D6, LCD_PINS_D7);
  lcd.begin(LCD_WIDTH, LCD_HEIGHT);
  lcd.display();
  lcd.noCursor();
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Hello, World!");
  pinMode(BEEPER,OUTPUT);
  digitalWrite(BEEPER,HIGH);
  delay(100);
  digitalWrite(BEEPER,LOW);
  lcd.print(millis() / 1000);
for some reason the lights don't even come on and I never hear the expected beep.
When i use the exact same pins with Marlin, everything works.
I just can't see what I've missed.  Contrast dial is not the issue.  swapping out hardware makes no diff.  I know the panel works
Dance as if no one is watching; post as if it is going to be read aloud as evidence in court.
johnwasser
Code: [Select]
EXP1:
Mega    CON     Mega
37      1  2      35
17      3  4      16
23      5  6      25
27      7  8      29
GND     9 10      48
EXP2:
Mega    CON     Mega
49      1  2      NC
31      3  4      52
33      5  6      50
+5V     7  8      41
NC      9 10      NC
Something is wrong here.  According to the schematic of the RepRap Discount Smart Controller this would source VCC from Pin 48 and connect the SD Card Detect switch to VCC.
https://reprap.org/mediawiki/images/7/70/Controller_final_reprapdiscount.pdf
Code: [Select]
EXP1:
1 37 Beeper
2 35 BC111E5244B2 Encoder Pin 5
3 17 LCD-Enable (Pin 6)
4 16 LCD-RS (Pin 4)
5 23 LCD-D4 (Pin 11)
6 25 LCD-D5 (Pin 12)
7 27 LCD-D6 (Pin 13)
8 29 LCD-D7 (Pin 14)
9 GND Ground
10 48 VCC ?!?
EXP2 (a.k.a. JP3):
1 49 SD-Card MISO
2 NC SD-Card SCK
3 31 BC111E5244B2 Encoder Pin 3
4 52 SD-Card SS
5 33 BC111E5244B2 Encoder Pin 1
6 50 SD-Card MOSI
7 +5V SD-Detect
8 41 Reset button to Ground
9 NC NC
10 NC NC
johnwasser
I think I see the problem.  In the schematic for the Smart Controller adapter board I think they got the AUX-3 (SPI) connector rotated 180 degrees so the numbering  doesn't match the numbering on the RAMPS 1.4 schematic.
https://reprap.org/mediawiki/images/7/79/LCD_connect_SCHDOC.pdf
LCD Adapter schematic shows AUX-3 connections as:
Code: [Select]
1 NC 2 GND
3 D53 4 SCK
5 MOSI     6 MISO
7 D43 8 VCC
The RAMPS 1.4 schematic shows AUX-3 connections as:
Code: [Select]
1 VCC 2 D49
3 D50(MISO) 4 D51(MOSI)
5 D52(SCK) 6 D53(SS)
7 GND 8 NC
johnwasser
Code: [Select]
RepRap Discount Smart Controller Schematic
EXP1:
1 Beeper
2 BC111E5244B2 Encoder Pin 5
3 LCD-Enable (Pin 6)
4 LCD-RS (Pin 4)
5 LCD-D4 (Pin 11)
6 LCD-D5 (Pin 12)
7 LCD-D6 (Pin 13)
8 LCD-D7 (Pin 14)
9 GND
10 VCC
EXP2 (labeled JP3 on the schematic):
1 SD-Card MISO
2 SD-Card SCK
3 BC111E5244B2 Encoder Pin 3
4 SD-Card SS
5 BC111E5244B2 Encoder Pin 1
6 SD-Card MOSI
7 SD-Detect
8 Button to Ground labeled RESET
9 NC
10 NC
RAMPS 1.4 schematic showing AUX-3 and AUX-4 connectors
where the adapter board is connected:
https://reprap.org/mediawiki/images/f/f6/RAMPS1.4schematic.png
AUX-3 SPI (4x2):
1 VCC
2 D49
3 D50(MISO)
4 D51(MOSI)
5 D52(SCK)
6 D53(SS)
7 GND
8 nc
AUX-4 (18x1):
1 VCC
2 GND
3 D32
4 D47
5 D45
6 D43
7 D41
8 D39
9 D37
10 D35
11 D33
12 D31
13 D29
14 D27
15 D25
16 D23
17 D17
18 D16
RAMPS 1.4 LCD Adapter Schematic showing the connections
between EXP1/EXP2 and AUX-3/AUX-4
WARNING! The AUX-3 pins are numbered differently on this
schematic than on the RAMPS 1.4 schematic!
1 NC 2 GND
3 D53 4 SCK
5 MOSI 6 MISO
7 D43 8 VCC
1 VCC 2 D49
7 GND 8 NC
If you believe the labels or the pin numbers the schematic makes no sense:
AUX-3 (4x2):
1 nc EXP1-9 GND
2 GND nc
3 D53(SS) EXP2-2 SD-Card SCK
4 D52(SCK)  EXP2-4 SD-Card SS
5 D51(MOSI) EXP2-1 SD-Card MISO
6 D52(MIS0) EXP2-6 SD-Card MOSI
7 D43 EXP1-10 VCC
8 5V EXP2-7 SD-Detect
If you ignore the labels and the pin numbers on this schematic
and use the numbering from the RAMPS 1.4 schematic, you get this:
AUX-3 (4x2):
1 VCC EXP1-10 VCC
2 D49 EXP2-7 SD-Detect
3 D50(MISO) EXP2-1 SD-Card MISO
4 D51(MOSI) EXP2-6 SD-Card MOSI
5 D52(SCK)  EXP2-2 SD-Card SCK
6 D53(SS) EXP2-4 SD-Card SS
7 GND EXP1-9 GND
8 nc nc
The AUX-4 looks correct.
AUX-4 (18x1):
1 VCC nc
2 GND nc
3 D32 nc
4 D47 nc
5 D45 nc
6 D43 nc
7 D41 EXP2-8 Button to Ground labeled RESET
8 D39 nc
9 D37 EXP1-1 Beeper
10 D35 EXP1-2 BC111E5244B2 Encoder Pin 5
11 D33 EXP2-5 BC111E5244B2 Encoder Pin 1
12 D31 EXP2-3 BC111E5244B2 Encoder Pin 3
13 D29 EXP1-8 LCD-D7 (Pin 14)
14 D27 EXP1-7 LCD-D6 (Pin 13)
15 D25 EXP1-6 LCD-D5 (Pin 12)
16 D23 EXP1-5 LCD-D4 (Pin 11)
17 D17 EXP1-3 LCD-Enable (Pin 6)
18 D16 EXP1-4 LCD-RS (Pin 4)
AUX-3 (4x2):
1 VCC EXP1-10 VCC
7 GND EXP1-9 GND
8 nc nc
JRRster
Hello, I'm currently working on a project using the REPRAPDISCOUNT smart controller. The project requires me to write information to an SD card and I am having trouble getting it to initialize. I'm assuming this has to do with the pin layout. Can someone here tell me how to redefine the each pin for the SD card? I know I need "#define" and then the name of the pin but I'm not sure how to do it on the smart controller.
DanielleinaD
my test is:
Code: [Select]
#define BEEPER             37
#define BTN_EN1            31
#define BTN_EN2            33
#define BTN_ENC            35
// SD card settings
#define SDPOWER            -1
#define SDSS               53
#define KILL_PIN           41
  lcd.display();
  lcd.noCursor();
  lcd.clear();
  delay(100);
Hi
I just uploaded your code and it's working fine. bip and Hello word, but your board is not looking as this one https://reprap.org/wiki/RepRapDiscount_Smart_Controller
