Topic: Read two messages with different timings (Read 396 times) previous topic - next topic
HelloArduinoWorld
Hello,
So i am trying to read two can messages with different timing and save and compare them without using delays. how do i do it?
Delta_G
#1
Jul 09, 2018, 06:31 pm Last Edit: Jul 09, 2018, 06:33 pm by Delta_G
Using the technique from the "Blink Without Delay" example.
If you want a more detailed answer you'll have to ask a much more detailed question.  You didn't really give me much to go on there.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
HelloArduinoWorld
#2
Jul 09, 2018, 07:44 pm Last Edit: Jul 09, 2018, 08:24 pm by HelloArduinoWorld
Here is my code. . i have two devices with the same can id but are on different can networks. my difference is either -voltage1 or -voltage2. please help out.
#include <mcp_can.h>
#include <SPI.h>
float Voltage1;
float Voltage2;
const int SPI_CS_PIN1 = 9; // select pin 9
const int SPI_CS_PIN2 = 10 ; // select pin 10
MCP_CAN CAN1 (SPI_CS_PIN1);
MCP_CAN CAN2 (SPI_CS_PIN2);                                     // Set CS pin
  if (CAN_OK != CAN1.begin(CAN_500KBPS) || CAN_OK != CAN2.begin(CAN_500KBPS) )              // init can bus : baudrate = 500k
    Serial.println("CAN BUS Shield init fail");
    Serial.println(" Init CAN BUS Shield again");
    delay(100);
  Serial.println("CAN BUS Shield init ok!");
  unsigned char len1 = 0;//
  unsigned char buf1[8] = {00, 00, 00, 00, 00, 00, 00, 00};
  unsigned char len2 = 0;
  unsigned char buf2[8] = {00, 00, 00, 00, 00, 00, 00, 00};
  if (CAN_MSGAVAIL == CAN1.checkReceive())        // check if data coming
    CAN1.readMsgBuf(&len1, buf1);
    unsigned int canId1 = CAN1.getCanId();
    if (canId1 == 768)
      unsigned int x1 = buf1[2]; //Select bit
      unsigned int y1 = buf1[3];
      unsigned int z1 = x1 * 256 + y1; //concatenate
      Voltage1 = z1 * 0.002; //Convert obtained decimal value to voltage
       Serial.println(Voltage1);
  if (CAN_MSGAVAIL == CAN2.checkReceive())
    CAN2.readMsgBuf(&len2, buf2);
    unsigned int canId2 = CAN2.getCanId();
    if (canId2 == 768)
      unsigned int x2 = buf2[2]; //Select bit
      unsigned int y2 = buf2[3];
      unsigned int z2 = x2 * 256 + y2; //concatenate
      Voltage2 = z2 * 0.002; //Convert obtained decimal value to voltage
       Serial.println(Voltage2);
  float difference = Voltage1 - Voltage2;
  Serial.println(difference);
PaulS
I see nothing in your code that cares about timing. Why don't I?
HelloArduinoWorld
if i knew how to. i wouldn't be posting this question.
PaulS
You are pulling messages. How can you know when to pull them? There will be nothing to pull, if a device doesn't have a message for you to pull. Why do you think that "as-fast-as-they-become-available" isn't the right way to read them?
sherzaad
your code is not waiting for BOTH "Voltage1" and "Voltage2" to be available... easy enough to fix
just to confirm: does the voltage difference be "Voltage1 - Voltage2" or can it also be "Voltage2 - Voltage1"?
Robin2
You have not really described your requirement clearly and I suspect if you did you would see yourself how to do it.
I wonder (and I may be completely wrong) if you want to compare the most recent values from each input. You could do that by having a variable that records when a new value arrives for each input - something like this pseudo code
if a value arrives at inputA
    newInputA = true
if a value arrives at inputB
   newInputB = true
if (newInputA == true and newInputB == true)
   diff = valueA - valueB
   newInputA = false
   newInputB = false
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
HelloArduinoWorld
Robin2
Thank you all. Solved it
It is usual to share your solution for the benefit of other readers.
...R
HelloArduinoWorld
The same concept you told me about in your reply. i just did that and it worked.
Robin2
Thanks for the feedback. I had imagined from your Reply #8 that you had found a very different solution.
...R
