Topic: Perboard Brownout but Works with Wires (Read 2497 times) previous topic - next topic
czu001
Jul 12, 2018, 03:57 am Last Edit: Jul 12, 2018, 03:58 am by czu001
This will be my first perfboard, and I bought the perma-protoboard from Adafruit (https://www.adafruit.com/product/571).  I am able to get my project to work with the soldered perfboard when I run wires from the Arduino; however, when I actually "plug" the Arduino into the perboard, I start getting exceptions and "Brownout detected".  After that, my solenoid just "buzzes" and I quickly unplug the Arduino.
I have attached two pictures for reference.  I soldered a header kit into the protoboard so that I could easily take out the Arduino if I needed to.  I have no idea why this is happening.  I even tried soldering just the pins necessary on the Arduino and then plugging that in, but I get the same issue.
The second picture is with the Arduino plugged in, and that's the configuration that causes brownouts.
I have no idea why this is happening.  I guess I can just use wires, but why won't it work when plugged into the perfboard?  Thanks!
DrDiettrich
My crystal ball indicates shorts in the soldered headers, perhaps missing jumpers.
"Brownout" means excess current draw and consequential operating voltage drop.
czu001
The soldered headers on the protoboard or the Arduino?  If that's the case, then do you have a suggest as to why it works with jumper wires from the Arduino to the soldered header on the perfboard, but not work without the jumper wires (header on Arduino straight into the header on the perfboard).
It sounds like I may need to draw a schematic, but most of my parts are components I've purchased from Pololu (motor driver, voltage regulator).
czu001
After thinking about it... maybe it's a bad soldering job on the proto-board headers.  Maybe some of the solder is touching somewhere and that is causing the short?
DrDiettrich
Right, check all header pins on the protoboard for shorts, in detail for shorts to Gnd or 5V. You can plug in wires to all pins one by one, and find out which wire/pin causes the problem.
wvmarle
Usually a good idea to do this BEFORE you start building...
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
TomGeorge
Do you have a DMM that you can use to check for shorts between the header pins?
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
spycatcher2k
Quote
because the issue would be on pins you have not jumped to the boards.
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
TomGeorge
Can you post a clear picture of the solder side of your circuit board please?
Thanks.. Tom.. :)
larryd
"I am able to get my project to work with the soldered perfboard when I run wires from the Arduino; however, when I actually "plug" the Arduino into the perboard, I start getting exceptions and "Brownout detected".  After that, my solenoid just "buzzes" and I quickly unplug the Arduino.
Really ??? do you think perhaps you made an assembly error?
No technical PMs.
The last thing you did is where you should start looking.
czu001
#10
Jul 13, 2018, 05:13 am Last Edit: Jul 13, 2018, 05:15 am by czu001
Thanks for the great feedback!  So, I a ran a jumper from the Arduino to the soldered header one by one, and I was never able to trigger the brownout.  It only happens when I plug the Arduino directly into the board.  The only thing I can think of is the header pins on the Arduino are maybe longer than the jumper wire pins, and there's a bad solder connection somewhere on the header on the protoboard.
I even tried a different Arduino (same kind), and I got the same issue.  So I'm pretty sure it's the header on the protoboard.  I've included some pictures of the bottom of the protoboard.  I'm definitely open to any critiques or feedback on how to do a better solder job... I do have a few places it's bled onto an un-used hole, but I didn't think that would be a problem since it's on the same rail.
Only thing I can think to do now is to de-solder the header on the board and try again.  Although that's a lot of pins... and I've never de-soldered before.
When I try again.. i may just solder the header where I need the pins instead of the entire header.
Daz1712
I notice from your photos, that when using jumper wires you are plugging an external battery into the Arduino but when you plug the board in you run from the supply on the other board.
A brownout means the power has dropped to unexceptable levels this may mean your supply on the board is faulty (going to the Arduino).
This would be overridden by the battery on the Arduino while running on the wires.
Highest voltage supplies the circuit.
Daz
wvmarle
For proper simulation you would have to connect all jumpers at once, not one by one. The problem could be between two normally unconnected ones. Or some other combination.
Overall soldering looks good to me, on the photos. Nice and tidy, no excess solder.
Quote
Less mechanical strength if you do it like that.
TomGeorge
Soldering looks good, just desolder the unused pins and see what happens.
Don't remove the pins,  just take the solder away, a good job for desolder wik.
Tom... :)
czu001
#14
Jul 13, 2018, 05:31 pm Last Edit: Jul 13, 2018, 05:31 pm by czu001
Thanks all!  Ordered some solder wick, and I'm going to try again.  I also connected all jumpers at the same time into the headers and still no brownout. I'm going to take the suggestions and first try to desolder the unused pins one by one and see what happens.  Thank you!
This forums is amazing.  I've gone from knowing nothing about electrical engineering to knowing enough to be dangerous :)
