Topic: Please help! How turn wav to binary data!!! (Read 929 times) previous topic - next topic
wgq6959424
Jul 14, 2018, 08:05 am Last Edit: Jul 17, 2018, 05:47 am by wgq6959424
we kown that Arduino system don't like c language have  file system
so,i use  Sd card save my .wav file.
but  SD.h  libraries  didn't have a like c language :
f.open("music.wav","rb")   // open a stream file use in binary system
f.open("music.wav","r")  just r,w ...No rb wb
and like  fread()   etc  fread("music.wav")   // reads data from the file stream
Please help me :  open a wav file  turn it to binary data.
thanks
pert
DON'T CROSS POST!!!!!!!!!!!!!!!!!!!!
http://forum.arduino.cc/index.php?topic=558023
I HAVE REPORTED THIS THREAD TO THE MODERATORS
TolpuddleSartre
All files contain binary data - there is no need to convert anything.
wgq6959424
but, some websites need to turn wav into binary transmission and identify them.
so,i need kown how turn wav bytes by bytes to binary data
thanks a lot
Paul_KD7HB
thanks a lot
To stop all the confusion, please give an example of a byte from a wave file and how you think that would be in binary.
Paul
MorganS
WAV is a very specific form of compression that works well for audio data. A small WAV file holds many megabytes of audio.
The Arduino memory is just a few kilobytes. It cannot hold even 1 second of uncompressed audio. What do you want to do with that tiny piece of data?
"The problem is in the code you didn't post."
wgq6959424
thank you for  MorganS reply
 I have a project about speech recognition using Arduino.The idea is to convert the wav file(The file size is about 8K) to Base64 to facilitate server identification.
The current progress is to turn wav into binary
slippyr4
That's not true at all. WAV is a container format and can contain audio data in a variety of different codecs. However, most commonly, WAV is used to store uncompressed linear PCM data.
MorganS
Hmmm italic code
That will read bytes from the file. But they are meaningless without decompression.
PaulS
Quote
I'm not sure if I read all the information contained in the entire wav file.
Why don't you? You know (or could, the library knows) the size of the file. You know how many bytes you read from the file. The numbers match and you've read all the data, or they don't, and you haven't.
pksato
#11
Jul 16, 2018, 04:32 pm Last Edit: Jul 16, 2018, 06:35 pm by pksato
Hi wgq6959424, and others,
A long time ago (1990) I managed to play wav files using a PC printer port and DAC/ADC. On the dark age on information. I get some information about .wav on magazines ans other pre internet information media.
The microsoft wave file have a 44 bytes of header, one of these bytes store the bit sample size, 8bit, 16 bits, etc.
I starting my study of Arduino, I dion't know all functions of API/ABI.
If wav file always have same format, just ignore first 44bytes and read rest of data according of know bit sample size.
PaulS
Quote
If wav file always have same format, just ignore first 44bytes and read data according of bit sample size.
If you ignore the first 44 bytes, you won't know the bit sample size, so reading the rest of the data "according of bit sample size" isn't going to work too well.
wgq6959424
Now it's my dark moment   (*>﹏<*)
Paul_KD7HB
Thanks Paul
ok. the example wav file at :  http://speech-doc.gz.bcebos.com/rest-api-asr/public_audio/16k.wav
The current idea is to open the wav file and then read each byte.
File myFile = SD.open("16k.wav");
byte buffer[256];
uint16_t  bufLen=myFile.read(buffer,256);
      for (uint16_t i=0;i<bufLen;i++){
            Serial.print(buffer,HEX);
        myFile.close();
Ok, was what you read "binary"? By now you surely realize every byte on every file is "binary".
Paul
