Topic: CONNECT ARDUINO YUN TO QNAP NAS VIA QIOT SUITE LITE (Read 2865 times) previous topic - next topic
SunnyYou
Get started with Arduino Yun (Python)
In this tutorial, you will learn the basics of working with Arduino Yun (that runs Linux). You will then learn how to seamlessly connect your devices to QNAP NAS using QIoT Suite Lite. This example is uses the DHT11 humidity and temperature sensor.
1. Configure your devices
1.1 Download Arduino IDE
Download and install the Arduino IDE based on your host PC:
https://www.arduino.cc/en/Main/Software
More Arduino tutorials can be found here:
https://www.arduino.cc/en/Tutorial/HomePage
1.2 Configure and test your devices
If this is your first time using Arduino Yun, you will have to follow some steps to assemble it.
Connect Arduino Yun to your PC with USB.
Open your Arduino IDE and find Blink example.
Configure your board:
Configure your port:
Verify and upload your Blink example to Arduino Yun
After uploading your code to Arduino Yun, check your Arduino Yun and you should see L13 blinking:
Connect your DHT11 sensor to "Ground", "5V", "Pin 2(Digital)" on Arduino Yun respectively.
1.3 Get the IP address of your Arduino Yun
Press and hold the Wi-Fi reset button for 5 seconds.
Go to your Wi-Fi settings and choose "Arduino-Yun-XXXXXXX"(where "XXXXXXX" is the MAC address of your Arduino Yun).
Open your browser and go to "http://192.168.240.1" or "http://arduino.local". The default password is "arduino".
Complete your Board setting and link your Arduino Yun to the router you are using. Skip "API setting"and click "Save".
On your PC, change your Wi-Fi network to your router and now your NAS and Arduino will be on the same network.
1.4 Install development tools for your Arduino Yun
Open a Terminal from http://arduino.local
Log in with the username "root" and your password. The default password is "arduino".
Install PIP and MQTT Library by entering the following commands.
2. Create your device in QIoT Suite Lite
2.1 Install QIoT Suite Lite
QIoT Suite Lite can be installed from the App Center.
Launch and log in to QIoT Suite Lite. The default username and password is "admin".
2.2 Create a new IoT application
IoT Applications are a combination of Things, Rules, and Dashboards. We recommend that you first create a "Things" in IoT Application. This IoT Application allows you to keep a record of all of the devices that are connected to your NAS.
Rules make it possible to build IoT applications that gather, process, analyze and act on data generated by connected devices. Rules can apply to data from one or many devices, and it can take one or many actions in parallel.
All these elements provide user a complete IoT Application environment.
If this is your first time using QIoT Suite Lite, click "Quick Setup Wizard" to start the quick setup wizard. After reading the introduction, click "Next".
Create a New IoT application
Enter the IoT Application name (for example: "app_1″).
The Rule name and Dashboard name will be automatically generated based on the IoT Application Name.
Click "Next".
Click "+ Add" to add this application's device.
Click "+Add", In "Add Things":
Enter a name for your device (for example: "arduino") and enter the device information (such as serial number and manufacturer) in Add attribute.
If your device is already supported by QIoT (Arduino Yun,Raspberry Pi, Edison, and Linkit 7688 (Duo)), choose a pre-defined Thing Type.
Click Add.
Enter the IP address, User Name, and Password of your device and click the Connect icon. QIoT Suite Lite will check the connection with the device. After the connection is verified, click Next.
In "Resources", click "Add Resource".
In "Add Thing Resource":
Enter the name and ID for the sensor in Resource Name and Resource ID. Please note that the Resource ID will be used to create a Topic in the QIoT Broker. This ID should be unique for the device and no duplicates should be allowed for the same device.
In "API Keys":
If you want to embed QIoT dashboard widgets into web pages or access QIoT APIs from third-party applications, go to the API Keys tab and click "Generate New API Key". Click "Done".
Your IoT application will now be created. Node.js sample codes and related files (certificate, resource information) will be uploaded to the specified path on your device.
A sample dashboard will be created.
Go to the Rule tab to define the flow or rules on how to process the data sent from the device, and how to present in a dashboard.
3. Connect your device to QIoT Suite Lite using MQTTS
3.1 Run Sample Code
Open Terminal application (such as: PuTTY) on your PC. Connect to your device using SSH and enter the folder where the smaple code is stored (for example: /home/root/bundle).
To install sample code dependencies, enter the following commands:
Run the sample code
The device will send a message to topic "temp" (or the topic you defined).
3.2 Another protocol
Click "Connect a Device".
You can select another protocol.
Connect to your device using SSH, and enter the following commands:
4. Integrate Power BI
4.1 Get your first Power BI account
Sign up for a free PowerBI account at https://powerbi.microsoft.com/en-us/
After a sequence of registration, the page will lead you to below page, you can press "My workspace", and "skip for now" button appear. You could click "skip for now "to start create dataset.
4.2 Setup your streaming dataset API
Create "Datasets"
Click "Create" in the top-right corner
Click "Streaming dataset"
Select "API", the source of your data, and click "Next".
Define your values from stream (e.g., temp, max, min), and you will get a JSON result in the textbox. We will use this JSON code to push data to the QIoT Suite Lite application. Click "Create" to finish.
Once you create your data stream, you get a REST API URL which IoT applications can call using POST requests to push your live data to the streaming data dataset you created.
4.3 Configure NodeRED's nodes in IoT application
Create IoT application in QIoT suite.
 The following is your first Node-RED flow, and then you can start creating your own IoT flow. You can learn more about Node-RED at https://nodered.org/
Before you start pushing live data to Power BI. We need a "function" node to convert IoT data to a streaming data dataset. Here you can replace msg.payload to your JSON dataset.
Function code as following:
We need an "http request" node to help us to push live data to Power BI. Just drop and drag "http request" node and connect to tail of "function" node.
Copy and paste the REST API URL that you got from the Power BI console, and set http method to POST. Click "Deploy" to save changes
Your Node-RED flow will look like below.
4.4 Add tile to display real-time data
Create "Dashboard"
Click "Create" in screen upper right corner
And then click "Dashboard"
Enter dashboard's name, and click "Create" to complete create dashboard.
Click "Add tile" in screen upper right corner
Select "CUSTOM STREAMING DATA" and click "Next".
Select datasets and click "Next".
Select visualization type (e.g., gauge), and set value, min, and max value.
You will have a streaming dataset to work with, and you can get a real time gauge that looks as following.
Please visit QNAP github for QIoT Suite Lite sample code "QNAP-Github"
Full image version of tutorial
https://qiot.qnap.com/blog/2018/05/18/arduino-yun-qnap-nasqiot-suite-lite/
