Topic: pwm (20 hz) con un pot (Read 316 times) previous topic - next topic
suly201211
I need a programming to control a led with a pwm signal, with a pot and with a frequency of 20 hz. Please
PaulS
Quote
Why? The normal PWM frequency is much higher than that.
wvmarle
I like this solution, found through a quick Google search on this very forum:
Code: [Select]
loop() {
 digitalWrite( 7 , (millis()%50 < 25) ? (HIGH) : (LOW)  )  ; // 20 Hz 50% duty cycle Pin 7
Or for higher resolution for your duty cycle (is that where the pot comes in?):
Code: [Select]
loop() {
 digitalWrite( 7 , (micros()%50000 < 25000) ? (HIGH) : (LOW)  )  ; // 20 Hz 50% duty cycle Pin 7
If you can explain how this works you may use it for your assignment :-)
Alternative (better if you have a lot of other things going on) is of course by using a timer interrupt.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
cedarlakeinstruments
I had a friend who used to do PWM the same way but with random numbers and it worked pretty well. ISTR that it keeps the switching noise down.
Electronics and firmware/software design and assistance. No project too small
6v6gt
And with what granularity do you want to change the duty cycle of the 20 Hz
Pwm? You'll probably get a number range of 0 to 1023 from the potentiometer by analogRead() and you'll have to base the duty cycle formula on that.
