So I've got a 12 volt car battery.
When the car battery is fully charged, it will fall down to 12.6 volts.
When the car battery is charging, it will be charged by 14 volts
My goal is to make the battery be only half charged, so i may charge it with something else.
I was actually thinking about using lithium ion cells because they will have a high nominal current, preventing the 14 volts from doing that much charging, and then the other power supply can have higher voltage.
or i was thinking about getting seven counts of two volt lead batteries, this will raise the battery voltage and the battery won't get charged by the now too low 14 volts.
Another problem is, what happens if I hook up two power sources in parallel. One has low voltage but high amperage. Other has 2 more volts but not as many amps. I'm don't know if the high voltage source will make the overall voltage higher when everything is connected, and then the amps from the first power source, whom aren't supposed to be used, will fly into the battery.
So should I put diodes and stuff to direct the flow of current to stop the possible high system voltage, or should i just put in relays that will control when is what connected. Also how am I going to get the main battery voltage if its under voltage and current and is at 14 volts?
