Topic: Any other way than modem.print ? (Read 886 times) previous topic - next topic
abbasben
I have an MKR1300 (MKRWAN.h + CayenneLPP.h) to use with TTN, but i have to use CayenneLPP data model, so I have a string with my message coded like "01 67 01 10" that it is the real message I want to receive on TTN.
If I use modem.print(msg), the result payload is one bye per character (16 at the end) and that's no the message I want to send, just need exactly what the string has. ¿ any idea to do it ?
Thanks in advance.
ballscrewbob
You would have to supply your sketch for people to be able to see just what and how your are using the print statements.
Please use code tags if you do ( </> ) as it makes the sketch easy to read properly.
There are a lot of Ethernet examples in the various Ethernet libraries maybe take a look at how some of those work or even some IOT examples that abound on the web.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
MITEL
modem.write(b) sends one byte. However, you have to extract them from your string (are you sure you really have a string?).
