Topic: [Solved] WiFiNINA (Read 1 time) previous topic - next topic
a2retro
Jul 28, 2018, 04:39 pm Last Edit: Aug 28, 2018, 11:40 am by mbanzi
Searching the libraries for Vidor I found the WiFiNINA lib that is supposed to support the Vidor4000. When I try to compile the WifiPing sketch i receive the following Warning and Error
Code: [Select]
WARNING: library SPI claims to run on (samd) architecture(s) and may be incompatible with your current board which runs on (samd_beta) architecture(s).
In file included from C:\Users\Glenn\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.22\cores\arduino/delay.h:23:0,
                 from C:\Users\Glenn\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.22\cores\arduino/Arduino.h:81,
                 from C:\Users\Glenn\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:21:
C:\Users\Glenn\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static void SpiDrv::begin()':
C:\Users\Glenn\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.22\variants\mkrvidor/variant.h:125:25: error: 'SPIEx' was not declared in this scope
 #define SPIWIFI         SPIEx
I did copy the VidorPeripherals Library code to my libraries folder under my sketches/libraries folder and I also did a include Libraries and selected VidorBase to add the base vidor headers to the project.
DarioPennisi
Hi Glenn,
we're completing wifi support. at the moment that should work in the graphics image but is not completely supported in the peripherals image. that should be updated early next week, adding also the serial interface which is now missing on both sides.
trupples
Bump? Both the VidorGraphics and VidorPeripherals repos haven't been updated in two weeks now...
tomtom2770
Regarding the github repos, it would be great to write some better commit messages than just "update".
 It helps to understand changes and also in case someone wants to debug something it can really help!
Thanks and keep up the great work!  ;)
jmcrine
Hello,
I'm the same problem, have you a solution ?
Regards
LarsCF
Is there something new about WiFiNINA?, I also gets the error message:
......\packages\arduino\hardware\samd_beta\1.6.22\variants\mkrvidor/variant.h:125:25: error: 'SPIEx' was not declared in this scope
DarioPennisi
almost there.. the graphics FPGA image we pushed yesterday has more or less everything needed. we just need to nail down some details on the arduino side.
sandeepmistry
Hi Everyone,
Please see the following thread on how to get the new library releases to use WiFiNINA: http://forum.arduino.cc/index.php?topic=563513.0
VA3SU
I still can't get wifinina to compile... Did the update:
New SAMD beta core 1.6.23 release, bootloader and library updates
Rather lengthy error list...
Arduino: 1.8.5 (Windows 7), Board: "Arduino MKR Vidor 4000"
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:333: undefined reference to `SpiDrv::waitForSlaveReady()'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:333: undefined reference to `SpiDrv::spiSlaveSelect()'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:336: undefined reference to `SpiDrv::sendCmd(unsigned char, unsigned char)'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:338: undefined reference to `SpiDrv::spiSlaveDeselect()'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:340: undefined reference to `SpiDrv::waitForSlaveReady()'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:341: undefined reference to `SpiDrv::spiSlaveSelect()'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:346: undefined reference to `SpiDrv::waitResponseCmd(unsigned char, unsigned char, unsigned char*, unsigned char*)'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:348: undefined reference to `SpiDrv::spiSlaveDeselect()'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:351: undefined reference to `SpiDrv::initialized'
C:\Users\Home\Documents\Arduino\libraries\WiFiNINA\src\utility/wifi_drv.cpp:787: undefined reference to `SpiDrv::initialized'
collect2.exe: error: ld returned 1 exit status
Using library SPI at version 1.0 in folder: C:\Users\Home\AppData\Local\Arduino15\packages\arduino\hardware\samd_beta\1.6.23\libraries\SPI
Using library WiFiNINA at version 1.1.0 in folder: C:\Users\Home\Documents\Arduino\libraries\WiFiNINA
exit status 1
Error compiling for board Arduino MKR Vidor 4000.
Juraj
#9
Aug 14, 2018, 09:14 pm Last Edit: Aug 14, 2018, 09:15 pm by Juraj
did you install it with Library Manager and update to 1.1.0?
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
sandeepmistry
Hi @VA3SU,
Could you please let us know what sketch you are compiling?
VA3SU
Sorry I should have said but I tried many of the sketches in the WifiNina, AP_Simplewebserver or Scannetworks.
Regards,
Kevin
VA3SU
And yes, did the library update to 1.1.0, and using the Arduino ide 1.8.5 of course.
sandeepmistry
Hi @VA3SU,
Could you please enable "Show verbose output during: compilation" in the IDE's preferences and provide the full build output.
I'm wondering if you library installation got corrupt somehow, as the Travis CI build for the library is working fine: https://travis-ci.org/arduino-libraries/WiFiNINA
VA3SU
Thanks for looking. File attached.
Build of AP simple web server
Regards,
Kevin
