Topic: Implementation for Microchip ENC28J60 Ethernet controller (Read 61171 times) previous topic - next topic
maniacbug
firstly I'm trying to finish the socket layer (implementing part of TCP and UDP stacks).
So, what's left to be done to get clients working?
alvarojusten
Yeah, I just pulled this, and compiled the examples, and they all compiled without any complaints.  This is on OSX.
Nice! Did you opened your browser to test if page load fine?
Blog pt_BR: http://blog.justen.eng.br/
Curso de Arduino (Arduino Course, in Brazil) - http://www.CursoDeArduino.com.br/
maniacbug
Nono, haven't touched the hardware yet.  Just pulled down the software and started to dig through it.
What do you suggest as a simple test to see if the connections are even hooked up right?
maniacbug
Ok, actually just for fun, I threw this together.
Running WebServerDEBUG, I get this:
Code: [Select]
DEBUG:
  INIT
DEBUG:
  ANSWERING_RECEIVED_ARP_REQUEST
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
DEBUG:
  INIT
DEBUG:
  IGNORING_PACKET_NOT_FOR_ME
DEBUG:
  INIT
DEBUG:
  INIT
DEBUG:
  INIT
And this is what I did to trigger it (and yes, I changed the IP address in the example to this one)
Code: [Select]
$ wget http://192.168.1.98/
--2011-03-27 20:47:21--  http://192.168.1.98/
Connecting to 192.168.1.98:80... connected.
HTTP request sent, awaiting response... Read error (Operation timed out) in headers.
alvarojusten
Code: [Select]
I know about this problem. The fact is that debugging uses too much memory and probably it needs more memory than an Arduino have. The version without debugging works perfectly. In the next days I'll work on this problem to reduce memory usage of debugging routines and hope it be fixed. Please see for updates on GitHub!
maniacbug
#20
Mar 29, 2011, 04:39 am Last Edit: Mar 29, 2011, 04:43 am by maniacbug Reason: 1
W00t!!
Code: [Select]
$ wget -O - -q http://192.168.1.98/
analog input 0 is 8<br />
analog input 1 is 1019<br />
analog input 2 is 434<br />
analog input 3 is 403<br />
analog input 4 is 366<br />
analog input 5 is 351<br />
Ok so like I said before...  What's left for the client?! :D
alvarojusten
W00t!!
Code: [Select]
Nice! :-)
Hahah. I need to debug TCP three-way handshake and modify send and disconnect functions.
maniacbug
Well, when you do, you've got a ready user and tester right here...
ITead
We make a slight change on the code and now it can work with our IE shield with D8 pin config  XD
http://arduino.cc/forum/index.php/topic,57006.0.html
alvarojusten
Nice! Can you send me the modifications?
GaryP
Where could I find magjacks? Seems to be out of stock in sparkfun, and I don't know any similar products.
Of course other solutions are possible, but I don't have experince with the interfacing of the ethernet.
Cheers,
Kari
The only law for me; Ohms Law: U=R*I       P=U*I
Note to self: "Damn! Why don't you just fix it!!!"
maniacbug
I am using a module from MDFly.com for $16.95: http://www.mdfly.com/index.php?main_page=product_info&cPath=9_41&products_id=109
It's out of stock now, but they seem to also have this...  http://www.mdfly.com/index.php?main_page=product_info&cPath=9_41&products_id=484
chiva
There are boards in eBay from 12$ shipping included
GaryP
I'm looking for this: http://www.sparkfun.com/products/8534
Price also matters...
Cheers,
Kari
pocketscience
Hey, this sounds great! I'll give it whirl and let you know! I've had troubles in the past with the ENC based shields, but just recently posted an apology to those shields... :-)
G.
