Topic: [Solved] FPGA boot loader recovery (Read 13764 times) previous topic - next topic
sandeepmistry
Aug 02, 2018, 07:21 pm Last Edit: Aug 28, 2018, 11:46 am by mbanzi
Hi Everyone,
We've prepared some manual steps to repair the FPGA's bootloader for those of you facing sketch upload issues.
To get started, download and extract the following URL, then follow the INSTRUCTIONS.txt file for the operating system you are using:
http://downloads.arduino.cc/tools/VidorFPGARecovery.zip
Please let us know if you have any issues.
NOTE: later on there will be an update to the core to prevent this issue.
ronsoul
just tried this on windows 10 and my mac.  They both fail at 49% on step 9 with SAM-BA operation failed
a2retro
Hi Dario or Sandeepmistry
Are you folks trying this code with devices pulled off the assembly line and not some pre built demo units prior to production?
sandeepmistry
Hi @a2retro,
I'm using 2 boards from the production batch. The recovery process works fine with my Mac.
I'm able to get my boards into the state where upload hangs between 46 - 49%, by loading a sketch that uses VidorPeripherals and double-tapping the reset button. Then I can recover the boards by following the instructions provided. However, the board might not be in the same state as yours.
@ronsoul do you have a powered USB hub to try the procedure with again?
ronsoul
@sandeepmistry
I do not have one but Ill order one.  Are you thinking its not getting enough power?
Thank you for the help,
Ron
sandeepmistry
Based on Dario's comments in http://forum.arduino.cc/index.php?topic=560394.msg3821794#msg3821794 ... maybe.
My colleague Cristian has also tried the instructions on Windows and Linux with out issues.
ronsoul
@sandeepmistry
I see.  It never worked even in bootloader mode connected to an iPad charger.  And I have it connected to a USB3 port.  Ill order one and report back on the results.
Thanks again,
Ron
stlitt
This appears to have fixed mine and I can now upload again! Thanks so much.
VA3SU
Thanks for posting the fix, VidorFPGARecovery.zip. It worked for me to solve the ~half upload freeze issue.
ronsoul
@sandeepmistry
I just received the powered usb hub.  Its still fails at 49% on step 9.
I have tried this on my windows 10 machine with USB3, a mac with USB3 and now with a powered usb hub on windows 10.  It seems like I may have a defective unit.  Whats the next step?
Ron
sandeepmistry
Hi @ronsoul
Instead of double-tapping the reset button, could you please try running this Python script to reset the board for the applicable steps:
Code: [Select]
#! /usr/bin/python
import sys
import serial
ser = serial.Serial(sys.argv[1], 1200)
ser.close()
Run with: python 1200bpsreset.py /dev/<PORT>
jcristine
Has there been any resolution to this?  I tried (with success) installing "VidorFPGARecovery.zip" on a mac. That part worked...
Now (still) uploads crash at 37%.
The uploads were working 60% of the time but now they are not at all:
Due to my original issue I removed and reinstalled the board definition files.
Original and still unsolved issue:
Copied and installed the "VidorDrawLogo" example from github, changed line 50:
vdgfx.println("ARDUINO");
to
vdgfx.println("MyARDUINO");
Also added a few debug lines:
  >Serial.println("Entering while() loop...");
  > while (1) {}
An I DO get the debug code to the whole "setup()" and "loop()" procs are running end-to-end but NO HDMI update.
The logo does not update on the HDMI screen to reflect my "My" change.
Now, due to my hacking away at this to get it to do the basics as I understand them, no more upload ability.
Thx - Jeff
jcristine
Update...
I tried to upload again - the upload worked but no update to the HDMI screen to reflect this change at line #50.
Now, much as before, it seems like the upload works 40% of the time.  Single device connected directly to a "MacBook Pro (Retina, 13-inch, Late 2012)".
My original issue is still open:
Line 50:  vdgfx.println("MyARDUINO"); // added "My"
HDMI screen does not show the update adding "My" to "ARDUINO".
I ALSO get this warning every time it compiles:
WARNING: library SPI claims to run on (samd) architecture(s) and may be incompatible with your current board which runs on (samd_beta) architecture(s).
sandeepmistry
#13
Aug 07, 2018, 11:10 pm Last Edit: Aug 07, 2018, 11:15 pm by sandeepmistry
Hi Everyone,
There was some issues with the bitstream provided in the original VidorGraphics library. We've pushed an updated version to Github: https://github.com/vidor-libraries/VidorGraphics
Please re-download the library and add to your sketchbook to get the fixes.
ronsoul
@sandeepmistry
Thank you for all of your help.  I still have the same issue it fails at 49% in step 9.  Is there anything else I can do?
Regards,
Ron
