Topic: [Solved] FPGA boot loader recovery (Read 13698 times) previous topic - next topic
dariopennisi
One thing most people don't notice is that some sketches such as Vidor draw logo wait for serial terminal to be open before doing anything, including initializing FPGA (there's a while loop waiting for serial to be opened). Also, we saw that some PCs tend to not be able to put the board in bootloader mode and this is something we are investigating. Please try uploading the board by manually entering bootloader by doubletapping the button. That should work.
jwestmoreland
Dario,
Any news on the bootloader issue and the wait on serial port open issue?
Thanks,
John W.
Limba
I think these were already fixed. I had serious problems with bootloader that come with vidor. After updating my bootloader my problems solved.
Also for vidor for waiting serial port to open is few lines in examples (draw logo). Just comment all lines that have "Serial" in it. Recommend to set IO pin for FPGA.begin failing indicator.
Code: [Select]
  // wait for the serial monitor to open,
  // if you are powering the board from a USB charger remove the next line
  while (!Serial);
  // Initialize the FPGA
  if (!FPGA.begin()) {
    Serial.println("Initialization failed!");
    while (1) {}
  delay(4000);
jwestmoreland
#33
Mar 16, 2019, 09:52 pm Last Edit: Mar 16, 2019, 09:59 pm by jwestmoreland
Limba,
I think the way to handle this has been suggested - I just hadn't seen it yet - I've coded up something like this so if the serial port is connected it can still be used:
#define SERIAL_COUNTER_TIME_OUT 5000    // so serial port doesn't hang the board
in setup():
unsigned int counter_main = 0;
  // in case serial port isn't connected:
 do {
      counter_main++;
 } while ( !Serial && ( counter_main < SERIAL_COUNTER_TIME_OUT) );
Maybe not the most efficient code but works for me.
Regards,
John W.
VStrakh
Hi.
It seems that fpga boot image's design sources was never released.
I'm considering replacing the boot image with own design, leaving more flash space for the application resources. But going through boot image recovery each time to enable uploading the new image/sketches is not really a good option.
So I'm wondering, what IP and/or software must be present in my design to allow SAMD' bootloader to access the flash for uploading purposes?
Any chances boot image design will be published, or there's some licensed IP?
jhinhwan
Thanks! This worked for me.
Previously I had a SAM-BA error while uploading the blink-sketch code:
https://hackaday.com/2018/11/01/hands-on-with-the-arduino-fpga/
Write 407667 bytes to flash (6370 pages)
[==================            ] 62% (3968/6370 pages)
SAM-BA operation failed
I downloaded the VidorFPGARecovery.zip and followed the steps in the instruction.txt file.
(I was amazed how long the activity log produced was, for the 3rd step.)
Now the previous code uploads and runs successfully. Thanks a lot!
