Topic: Problem with demo program - library file from github does not load into compiler (Read 521 times) previous topic - next topic
Wd0ug
REF: https://www.arduino.cc/en/Guide/MKRVidor4000
Trying to get the BLINK example working, I downloaded zip files from github.
Then, per instructions:
Sketch -> Include Library... -> Add .ZIP Library and select the file.
These zip files load into the library okay:
VidorBoot-master.zip
VidorGraphics-master.zip
VidorPeripherals-master.zip
This zip file does not load:
VidorFPGA-master.zip
Error message:
Arduino: 1.8.5 (Windows 10), Board: "Arduino MKR Vidor 4000"
Specified folder/zip file does not contain a valid library
What is the solution?  Thanks.
pert
VidorFPGA-master.zips.
Please point out the exact part of the instructions that lead you to think you should install that file that way so those instructions can be fixed to prevent future confusion.
The error message is telling the truth. VidorFPGA is not an Arduino library. From the repository's readme:
https://github.com/vidor-libraries/VidorFPGA
Quote
This repository includes FPGA IP Blocks compatible with the Arduino Vidor family of products and is aimed to users already familiar with FPGA development process.
