Topic: Code only works when serial monitor is open ! (Read 2270 times) previous topic - next topic
Whandall
#15
Aug 05, 2018, 07:23 pm Last Edit: Aug 05, 2018, 07:24 pm by Whandall
Hello psmelakt
"now the code works." : sure, one day or another you will have millis() >= 30000.
Crap. This is in setup, millis starts with zero and counts up, so "one day or another" happens after 30 seconds.
Have you read post #6 ?
which is
You are calling "while(!Serial);" before "Serial.begin()" - that may be an issue.
Why should anyone read that irrelevant superstitious post anyway?
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
bidouilleelec
Hello Wandall
Quote
Posted by Whandall
 - Today at 05:23 pm
    Quote
Quote from: bidouilleelec on Today at 05:17 pm
    Hello psmelakt
which is
Quote from: Danois90 on Aug 03, 2018, 01:53 pm
Are you sure? Did you test it?
I did.
Regards,
bidouilleelec
sterretje
Hello Wandall
I did.
Regards,
bidouilleelec
And what was the result?
I did test it numerous times in the past (and now again) and it does not make a difference as far as I can see.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
bidouilleelec
#18
Aug 06, 2018, 09:57 am Last Edit: Aug 06, 2018, 09:58 am by bidouilleelec
Hello Sterretje
Quote
The result is :
Post #6 is right.
Post #9 is just adding a delay and testing !Serial is unusefull as Serial.begin is after the test. (sure one day comes after 30ms)
Regards,
bidouilleelec
Whandall
You realize that the sketch works if there is a serial connection?
And that devices without native USB return true always?
That's what while (!Serial); is waiting for.
Adding a timeout to the endless wait makes the sketch work even if there is no serial connection.
The connection test (operator bool) does not need a begin before it can be used.
sterretje
The result is :
Post #6 is right.
Hmm, wonder wy my results are different (IDE 1.6.6, will try to test later with 1.8.5).
