Thank you so much! Finally works and perfectly generalized!
Will let folks at instructables know the Mega2560 code too.
#include "FastLED.h"
FASTLED_USING_NAMESPACE
#define DATA_PIN 10
//#define CLK_PIN 4
#define LED_TYPE WS2812B
#define COLOR_ORDER GRB
#define NUM_LEDS 6
CRGB leds[NUM_LEDS];
volatile byte BRIGHTNESS = 0;
#define FRAMES_PER_SECOND 120
#ifdef __AVR_ATmega2560__
#define PIN PINE
#define ABMASK 0b00110000
#define AMASK 0b00010000
#define BMASK 0b00100000
#endif
#ifdef __AVR_ATmega328P__
#define PIN PIND
#define ABMASK 0b00001100
#define AMASK 0b00000100
#define BMASK 0b00001000
#endif
static int pinA = 2; // Our first hardware interrupt pin is digital pin 2
static int pinB = 3; // Our second hardware interrupt pin is digital pin 3
static int pinC = 4;
volatile long pinCignoreCycles = 0; // the last time the output pin was sampled
volatile byte aFlag = 0; // let's us know when we're expecting a rising edge on pinA to signal that the encoder has arrived at a detent
volatile byte bFlag = 0; // let's us know when we're expecting a rising edge on pinB to signal that the encoder has arrived at a detent (opposite direction to when aFlag is set)
volatile byte encoderPos = 0; //this variable stores our current value of encoder position. Change to int or uin16_t instead of byte if you want to record a larger range than 0-255
volatile byte oldEncPos = 0; //stores the last encoder position value so we can compare to the current reading and see if it has changed (so we know when to print to the serial monitor)
volatile byte reading = 0; //somewhere to store the direct values we read from our interrupt pins before checking to see if we have moved a whole detent
volatile bool encoderMode = true; // 0 brightness // 1 pattern
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
delay(3000); // 3 second delay for recovery
// tell FastLED about the LED strip configuration
FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
//FastLED.addLeds<LED_TYPE,DATA_PIN,CLK_PIN,COLOR_ORDER>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
// set master brightness control
FastLED.setBrightness(BRIGHTNESS);
pinMode(pinA, INPUT_PULLUP); // set pinA as an input, pulled HIGH to the logic voltage (5V or 3.3V for most cases)
pinMode(pinB, INPUT_PULLUP); // set pinB as an input, pulled HIGH to the logic voltage (5V or 3.3V for most cases)
attachInterrupt(0,PinA,RISING); // set an interrupt on PinA, looking for a rising edge signal and executing the "PinA" Interrupt Service Routine (below)
attachInterrupt(1,PinB,RISING); // set an interrupt on PinB, looking for a rising edge signal and executing the "PinB" Interrupt Service Routine (below)
pinMode(pinC, INPUT_PULLUP);
Serial.begin(115200); // start the serial monitor link
void PinA()
// cli();
reading = PIN & ABMASK;
if(reading == ABMASK && aFlag)
encoderPos ++;
bFlag = 0;
aFlag = 0;
else if (reading == AMASK) bFlag = 1;
// sei();
void PinB()
cli();
if (reading == ABMASK && bFlag)
encoderPos --;
bFlag = 0;
aFlag = 0;
else if (reading == BMASK) aFlag = 1;
sei();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm, white, red,redglitter, green,greenglitter, blue };
byte b; // used to detect if brighness have overflowed
void loop(){
if(oldEncPos != encoderPos) {
if (encoderMode) {
if (oldEncPos > encoderPos) {
b = BRIGHTNESS;
BRIGHTNESS -= 15;
if(BRIGHTNESS > b) {
BRIGHTNESS = 0;
b = BRIGHTNESS;
BRIGHTNESS += 15;
if(BRIGHTNESS < b) {
BRIGHTNESS = 255;
if (!encoderMode) {
prevPattern();
nextPattern();
Serial.print("C:");
Serial.print(BRIGHTNESS);
Serial.print(",");
Serial.print(gCurrentPatternNumber);
Serial.println(".");
oldEncPos = encoderPos;
if (pinCignoreCycles > 0) {
pinCignoreCycles--;
if(pinCignoreCycles == 0) {
if(digitalRead(pinC) == LOW) {
pinCignoreCycles = 25;
Serial.println("Btn");
encoderMode = !encoderMode;
// Call the current pattern function once, updating the 'leds' array
gPatterns[gCurrentPatternNumber]();
// send the 'leds' array out to the actual LED strip
FastLED.show();
// insert a delay to keep the framerate modest
FastLED.delay(1000/FRAMES_PER_SECOND);
// do some periodic updates
EVERY_N_MILLISECONDS( 20 ) { gHue++; } // slowly cycle the "base color" through the rainbow
EVERY_N_SECONDS(30) {
if(BRIGHTNESS > 0) {
BRIGHTNESS--;
Serial.print("A:");
Serial.print(",");
if (BRIGHTNESS == 0) {
encoderMode = true; //fall back to brightness mode
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
// add one to the current pattern number, and wrap around at the end
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void prevPattern()
gCurrentPatternNumber = (gCurrentPatternNumber - 1);
if (gCurrentPatternNumber > ARRAY_SIZE(gPatterns)) {
gCurrentPatternNumber = ARRAY_SIZE(gPatterns)-1;
void rainbow()
// FastLED's built-in rainbow generator
fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter()
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
if( random8() < chanceOfGlitter) {
leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
// random colored speckles that blink in and fade smoothly
fadeToBlackBy( leds, NUM_LEDS, 10);
int pos = random16(NUM_LEDS);
leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon()
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, NUM_LEDS, 20);
int pos = beatsin16(13,0,NUM_LEDS);
leds[pos] += CHSV( gHue, 255, 192);
void bpm()
// colored stripes pulsing at a defined Beats-Per-Minute (BPM)
uint8_t BeatsPerMinute = 62;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
for( int i = 0; i < NUM_LEDS; i++) { //9948
leds[i] = ColorFromPalette(palette, gHue+(i*2), beat-gHue+(i*10));
void juggle() {
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for( int i = 0; i < 8; i++) {
leds[beatsin16(i+7,0,NUM_LEDS)] |= CHSV(dothue, 200, 255);
dothue += 32;
void white() {
for(int i=0; i < NUM_LEDS; i++) {
leds[i] = 0xFFFFFF;
void red() {
leds[i] = 0x00FF00;
void redglitter() {
leds[i] = 0x00FF00;
addGlitter(80);
void green() {
leds[i] = 0xFF0000;
void greenglitter() {
leds[i] = 0xFF0000;
addGlitter(80);
void blue() {
leds[i] = 0x0000FF;
