Topic: [SOLVED] FPGA clock (Read 428 times) previous topic - next topic
riccardo_giacomazzi
Aug 09, 2018, 04:46 pm Last Edit: Aug 28, 2018, 11:52 am by mbanzi
The clock signal that can be used in the FPGA to drive PLLs is that of pin E2?
The one called SAM_PORTS.GCLK?
If so, what frequency does it have? 48MHz?
DarioPennisi
Hi Riccardo,
Yes, we are deriving all clocks from pin E2 using a PLL. current bootloader is set to drive that pin at 48 MHz when you call FPGA.begin().
alternatively you can use the internal oscillator in the FPGA however that can't drive a PLL so it probably won't be of much use unless you need a clock which is present also if SAM is not clocking FPGA.
riccardo_giacomazzi
In the VidorUtils.h file I find it written:
Code: [Select]
// Start clocking the FPGA; this function is declared weak and can be overridden
// with a custom implementation (or can be left untouched if FPGA is clocked internally)
enableFpgaClock();
And indeed, shortly before, the enableFpgaClock() function is defined as follows:
Code: [Select]
__attribute__((weak)) void enableFpgaClock() {}
So, at the moment, there is no way to enable the clock? Or is it always enabled?
riccardo_giacomazzi
I answer myself, the function enableFpgaClock() is redefined in the variant.cpp file of the mkrvidor variant:
Code: [Select]
  // Will be called by the Vidor library begin()
  pinPeripheral(30, PIO_AC_CLK);
  clockout(0, 1);
