Topic: question on solar and transistors (Read 497 times) previous topic - next topic
tjones9163
Hello, I have recently been experimenting with very small solar cells. I have hooked up 2 solar cells in series and with bright light shined upon the solar panel, i am able to light up and LED. now I also tried hooking the positive terminal of my solar panel to the base of an NPN transistor with a 10k resistor also on base and also used my solar panel to provide positive and negative for my transistor. this circuit did work but not work as well as when I just used the panel and led. Is this because NPN transistors work with current and not voltage, so there is not much to amplify?? and my second question--Could the reason the transistor circuit did not work as well is that I am dealing with low voltage to begin with and because of the voltage drop from the transistor?? would a mosfet be better?
Thanks
pic of the solar cells below
jremington
Draw a circuit diagram and post it. If you don't know how to do that, now is the time to start learning.
Here is a great place to start.
tjones9163
My best attempt at circuit diagram attached below
thanks for response
tjones9163
thanks for the response. I replied below with a diagram, I wasn't sure how to attach a pic to your quote but thanks again
jremington
#4
Aug 11, 2018, 05:15 am Last Edit: Aug 11, 2018, 05:15 am by jremington
OP's pic (which is fine):
What transistor is that? To saturate the transistor you may need a lower value base resistor. You are assuming current gain = 100 or roughly, 10K/100 Ohms, which is probably too high. Try 2K.
tjones9163
thanks for response, the transistor is an NPN Transistor(8050) , I have tried with a 3.3k resistor on the base but it still doesn't work as well as when i just use the solar panel and led, could this be because of the voltage drop of Transistor, and also i heard that these type of transistor work with current not voltage, could that be a factor?
Thanks
jremington
#6
Aug 11, 2018, 05:27 am Last Edit: Aug 11, 2018, 05:28 am by jremington
Quote
What does that mean? Did you have a 100 Ohm resistor in series with the LED? If not, don't you think that would have an effect?
Always post a circuit diagram, so we know what you are talking about.
Hint: buy a multimeter, so you can measure currents and voltages. Very, very informative!
tjones9163
#7
Aug 11, 2018, 05:33 am Last Edit: Aug 11, 2018, 05:33 am by tjones9163
This is a circuit with just Solar panel and LED-resistor, which works better work than transistor circuit.
tjones9163
I know my old cen-tech DMM stopped working but is also very old. I need to save up for a new one. Hopefully soon lol
mauried
What is it that you are expecting the transistor to do?
It wont make the led any brighter, and because there will a small voltage drop across the transistor, the led will be dimmer.
tjones9163
I'm actually not sure lol, just experimenting. But let's say I connected even more together in series, couldn't I do the same setup with the transistor and able to handle devices that require higher current. I'm not sure because I am new to solar panels but will it hurt or damage my solar cells if I hook them directly up to what I am trying to power without a transistor in between? would a mosfet perhaps be a better choice? I do not know. I do also realize that there are manufacture made inverters and charge controllers for solar but I want to learn with basic electronic components.
Thanks for response.
jremington
Quote
No.
