Topic: using raspberry pi 3 b+ (Read 1 time) previous topic - next topic
chrislittler
i can only use raspberry pi 3 b+ to program my arduino uno. As the raspberry pi has an older version of the arduino ide will this be a major problem in doing projects
chrislittler
is the version of the arduino ide on the raspberry pi still usable as it is an older version
Railroader
Why not use the latest corresponding version from Arduino?
Use Your knowledge. If that's not enough, look for education.
Having knowledge, think outside the box to gain more of it. Only trains run like the train, on the rails. The rest run between the rails.
Grumpy_Mike
Yes
chrislittler
Robin2
#5
Aug 18, 2018, 09:14 am Last Edit: Aug 18, 2018, 09:15 am by Robin2
Probably not.
You have not told us what version of the IDE is on your RPi?
Why not upgrade to a newer version if you need the newer features (whatever they are - I'm still using 1.6.3 on this laptop for most things)
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Coding Badly
Grumpy_Mike
Probably not.
Yes I did a project just two months ago with a fresh install of the Pi 3 b+ and it worked fine.
chrislittler
I don't think you can get the latest version on raspberry pi if you can I'd like someone to tell me how
Robin2
I don't have an RPi but I use Linux.
I just download the appropriate  tar file, extract its contents to a suitable folder, CD to that folder, double-click the arduino file and it just works.
...R
gdsports
You can always gets the latest version (currently 1.8.5) of the IDE from here. For Raspberry Pi, download the Linux ARM version.
https://www.arduino.cc/en/Main/Software
