Topic: Calculate difference in heading direction to course direction?? (Read 2595 times) previous topic - next topic
wildbill
I expect so. Given the heading of the enclosure, the pointer should point at the desired destination. Try it & see!
jremington
MarkT
For a difference in bearing, the formula is:
(540 + bearing_a - bearing_b) % 360 - 180
Note the % operator is only seeing positive values since the C % operator is not mathematically correct
with negative values, which is why 540 is used rather than 180.
The result is clearly constrained to +/-180
