Topic: Vacuum sensor for automotive assisted brakes (Read 6041 times) previous topic - next topic
daveg360
Yeah you should be able to find a suitable MAP sensor.  Some NA engines use them to measure manifold vacuum.
P18F4550
Apart from connecting to the obd port on my car i don't screw around with anything electomechanical in my car especially something as critical as brakes
GordonEndersby
If you arnt confident and dont know what you are doing then I suggest you dont.
I am confident and do know what I am doing.
The sensor arrived this morning. £19.99 including delivery.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250540286109&ssPageName=STRK:MEWNX:IT
Hooked up 5v, ground and my multimeter to the sensor output and it works.
Had to do a bit of digging to find pin out.
They are labelled A, B & C inside the connector.
A - 5v
B - Gnd
C - Signal
They are not all the same. On some B & C are switched.
Had 4.5v at atmosphere.
Sucked hard on it and got it down to about 3.5v
Now I need to rig something up to test it on the car.
And yes by rig something up I do mean I will make it safe and ensure that I dont lose my brakes and crash into the nearest nuclear power station and inadvertently start world war 3.
Gordon
P18F4550
Good luck, no i would not b confident
