Topic: capacidad tarjeta rfid 13.56 mHz (Read 470 times) previous topic - next topic
Adrian_E
hola, estoy probando con  tarjeta rfid 13.56 mHz 1Kb, hasta ahora he logrado grabar 30 caracteres contando los espacios, eso es lo maximo o hay alguna manera de grabar mas datos? el mudulo es el siempre bien ponderado módulo Lector RFID RC522  :)
Adrian_E
A nadie le pasa de solo poder grabar solo 30 caracteres?
Adrian_E
algun alma piadosa, sigo con el mismo problema, uso los ejemplos de MFRC522 y nada solo 30 caracteres
Adrian_E
este es el codigo que estoy usando
Code: [Select]
 * Write personal data of a MIFARE RFID card using a RFID-RC522 reader
 * Uses MFRC522 - Library to use ARDUINO RFID MODULE KIT 13.56 MHZ WITH TAGS SPI W AND R BY COOQROBOT.
 *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
 *             Reader/PCD   Uno/101       Mega      Nano v3    Leonardo/Micro   Pro Micro
 * Signal      Pin          Pin           Pin       Pin        Pin              Pin
 * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
 * SPI SS      SDA(SS)      10            53        D10        10               10
 * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
 * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
 * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
 * Hardware required:
 * Arduino
 * PCD (Proximity Coupling Device): NXP MFRC522 Contactless Reader IC
 * PICC (Proximity Integrated Circuit Card): A card or tag using the ISO 14443A interface, eg Mifare or NTAG203.
 * The reader can be found on eBay for around 5 dollars. Search for "mf-rc522" on ebay.com.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN         9           // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance
  Serial.begin(9600);        // Initialize serial communications with the PC
  SPI.begin();               // Init SPI bus
  mfrc522.PCD_Init();        // Init MFRC522 card
  Serial.println(F("Write personal data on a MIFARE PICC "));
  // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
  MFRC522::MIFARE_Key key;
  for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  Serial.print(F("Card UID:"));    //Dump UID
  for (byte i = 0; i < mfrc522.uid.size; i++) {
    Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(mfrc522.uid.uidByte[i], HEX);
  Serial.print(F(" PICC type: "));   // Dump PICC type
  MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
  Serial.println(mfrc522.PICC_GetTypeName(piccType));
  byte buffer[34];
  byte block;
  MFRC522::StatusCode status;
  byte len;
  Serial.setTimeout(20000L) ;     // wait until 20 seconds for input from serial
  // Ask personal data: Family name
  Serial.println(F("Type Family name, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 30) ; // read family name from serial
  for (byte i = len; i < 30; i++) buffer[i] = ' ';     // pad with spaces
  block = 1;
  //Serial.println(F("Authenticating using key A..."));
  status = mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid));
  if (status != MFRC522::STATUS_OK) {
    Serial.print(F("PCD_Authenticate() failed: "));
    Serial.println(mfrc522.GetStatusCodeName(status));
    return;
  else Serial.println(F("PCD_Authenticate() success: "));
  // Write block
  status = mfrc522.MIFARE_Write(block, buffer, 16);
    Serial.print(F("MIFARE_Write() failed: "));
    return;
  else Serial.println(F("MIFARE_Write() success: "));
  block = 2;
    return;
  // Write block
  status = mfrc522.MIFARE_Write(block, &buffer[16], 16);
    return;
  // Ask personal data: First name
  Serial.println(F("Type First name, ending with #"));
  len = Serial.readBytesUntil('#', (char *) buffer, 20) ; // read first name from serial
  for (byte i = len; i < 20; i++) buffer[i] = ' ';     // pad with spaces
  block = 4;
    return;
  // Write block
    return;
  block = 5;
    return;
  // Write block
    return;
  Serial.println(" ");
  mfrc522.PICC_HaltA(); // Halt PICC
  mfrc522.PCD_StopCrypto1();  // Stop encryption on PCD
GO_zalo
Es que con el ejemplo que pones es para escribir dos bloques, no hay para más, debes hacer el buffer más grande y escribir en más bloques
Adrian_E
ok gracias, lo voy a poner en practica, el maximo son 8 bloques?
GO_zalo
Hay 16 sectores con cuatro bloques por sector, pero mírate primero la específicacion de las mifare 1k por que sino te vas a hacer un harton de romper tarjetas
Por otro lado las 4k tienes una zona más amplia y se leen con el mismo lector, te sería más fácil almacenar todos los datos en esa amplia zona que distribuirlo en varios sectores de una 1k
harkonnen
Como dice Go_zalo hay 16 sectores, cada sector tiene 4 bloques y cada bloque 16 bytes. 16*4*16=1024= 1K.
El bloque 0 del sector 0, el primero, contiene informacion del fabricante de la tarjeta y el UID de la tarjeta. Aquí no deberías escribir, a no ser que quieras clonar una tarjeta...
El cuarto bloque de cada sector es el 'sector trailer', que contiene las llaves de acceso al sector (por defecto 0xFFFFFFFFFFFF para las dos claves, a y b) y cuatro bytes denominados 'Access Bits', que según que pongas especifica que se puede hacer con las claves en el sector, leer, escribir, decrementar, incrementar, etc. Si escribes informacion al azar en ese bloque el sector puede quedar inservible...
mifare 1k
Adrian_E
ok, voy a ver si entiendo como agregar bloques para escribir, basándome en el sketch de arriba
