Topic: ESP32 output voltage on input pin (Read 1 time) previous topic - next topic
Damien98
Hi, I'm working on an ESP32 (Heltec) project and i'm facing this issue with GPIO4: when I set it as output it works fine but when I set it as input there's 3.3V on this pin, I need to read the voltage with analogRead() and the 3.3V of this pin change the real value. It seems like there's an internal pull-up resistor enabled.
Here's my easy code:
Code: [Select]
  pinMode(4,INPUT);
  Serial.println(analogRead(4));
BJHenry
Since you mention Heltec, I assume you are using either the Wifikit32 or the WifiLoRa32. On both of these boards GPIO4 is the SDA line for the onboard OLED, and it has a hardware pullup resistor.
