Topic: Python 3 Version of ComArduino2 (Read 339 times) previous topic - next topic
the_engineer
This Python - Arduino demo may be of interest.
Also see Serial Input Basics - simple reliable ways to receive data.
...R
Hi Robin2,
Excellent work on the 'ComArduino2.py'.
Any chance on a python 3 version of this code?
I'm suffering with the below error. (the arduino code works fine of course)
Code: [Select]
#  Function Definitions
def sendToArduino(sendStr):
  ser.write(sendStr)
def recvFromArduino():
  global startMarker, endMarker
  ck = ""
  x = "z" # any value that is not an end- or startMarker
  byteCount = -1 # to allow for the fact that the last increment will be one too many
  # wait for the start character
  while  ord(x) != startMarker:
    x = ser.read()
  # save data until the end marker is found
  while ord(x) != endMarker:
    if ord(x) != startMarker:
      ck = ck + x
      byteCount += 1
    x = ser.read()
  return(ck)
def waitForArduino():
   # wait until the Arduino sends 'Arduino Ready' - allows time for Arduino reset
   # it also ensures that any bytes left over from a previous message are discarded
    msg = ""
    while msg.find("Arduino is ready") == -1:
      while ser.inWaiting() == 0:
        pass
      msg = recvFromArduino()
      print(msg)
def runTest(td):
  numLoops = len(td)
  waitingForReply = False
  n = 0
  while n < numLoops:
    teststr = td[n]
    if waitingForReply == False:
      sendToArduino(teststr)
      print("Sent from PC -- LOOP NUM " + str(n) + " TEST STR " + teststr)
      waitingForReply = True
    if waitingForReply == True:
        pass
      dataRecvd = recvFromArduino()
      print("Reply Received  " + dataRecvd)
      n += 1
      print("===========")
    time.sleep(5)
# THE DEMO PROGRAM STARTS HERE
import serial
import time
# NOTE the user must ensure that the serial port and baudrate are correct
serPort = "COM4"
baudRate = 9600
ser = serial.Serial(serPort, baudRate)
print("Serial port " + serPort + " opened  Baudrate " + str(baudRate))
startMarker = 60
endMarker = 62
waitForArduino()
testData = []
testData.append("<LED1,200,0.2>")
testData.append("<LED1,800,0.7>")
testData.append("<LED2,800,0.5>")
testData.append("<LED2,200,0.2>")
testData.append("<LED1,200,0.7>")
runTest(testData)
ser.close
Error:
Code: [Select]
Traceback (most recent call last):
  File "C:/ComArduino2.py", line 158, in <module>
    waitForArduino()
  File "C:/ComArduino2.py", line 102, in waitForArduino
  File "C:/ComArduino2.py", line 80, in recvFromArduino
    ck = ck + x
TypeError: can only concatenate str (not "bytes") to str
Robin2
#1
Sep 03, 2018, 09:14 pm Last Edit: Sep 03, 2018, 09:15 pm by Robin2
Hi Robin2,
Try the attached file - just rename it to .py
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Coding Badly
