Topic: Soldering Option help (Read 2854 times) previous topic - next topic
srnet
Is tip tinner a necessity or can I get by with coating my tip with a bit of rosin core solder?
Not a necessity as in you dont need to stop soldering if you dont have one.
However they are well worth having, so much easier to clean and tin the tip.
I bought the standard tin of Multicore Tip cleaner (15g) about 30 years ago, around 30% used so far, so they do last.
No PMs please, they dont get answered.
westfw
It's important, IMO, to get a "temperature controlled" iron, rather than just an "adjustable" iron.
It might require some digging to figure out which is which, when looking at an iron with a dial...
SaintSkinny
That's a good point. I'm gonna have to keep that in mind when I shop for a more permanent iron. For now I went with this $4 ebay iron to get me through the first couple projects.
I dont have much in the way of expectations when it comes to this thing, I figured if it's junk I'm out less than five dollars, and I can go grab one from harbor freight instead.
polymorph
The last two are garbage. They are just a lamp dimmer (phase control PWM) with no temperature feedback.
Just because an iron is labeled in degrees, does not mean it has feedback. Just because it says "adjustable temperature", does not mean it has feedback.
The Circuit Specialist iron says "A front panel led will blink while the system is heating and then once the set temperature has been acquired, it will stop  blinking and stay on." That indicates temperature feedback.
I would not trust the Robot Shop iron. It only says "Adjustable Temperature", and in one place it says 30W, in two other places it says 60W.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
SaintSkinny
So the circuit specialist would be the best option of the 4 in the OP?
polymorph
I would say so.
I have a nº 2, with some other branding and it is ok, there are very cheap compatible tips on ebay so you can order what you need for a few bucks.
Just stay away from the very cheap 220V (or 110V in your case) AC irons where the tip is just a cooper(ish) rod, most of the times they will just burn the pads out from the PCB, an iron like the nº 2 will not.
About solder, choose something with about 0.6 - 0.8 mm with rosin core (no acid flux core), any 60/40 (60% lead, 40% tin) will do, but if you can spare just a bit more go for a 63/37, they look to be a bit better.
But if you're buying solder from china remember that you'll get what you're paying for... not much :-(
If you're using a wet sponge, distilled/deionized water is just a bit better but, really, for you or me it is not important. But grab a brass "sponge" it is much better and will not cool your iron.
You never learn anything by doing it right.
polymorph
I have a few of those. I mean that exact shape, but with two different brand names on them. They are just a lamp dimmer. Temperature takes a long time to stabilize, then it drops very quickly when you start soldering, and takes a long time to recover.
It is literally just a triac, diac, and the resistors and capacitors for a lamp dimmer.
$4 is too much.
SaintSkinny
$4 is too much.
I can't say I'm surprised, that's about all I expected for the price.... But luckily I won't have to use it for long :) ... I was talking with my Dad the other day and at some point I mentioned something about the iron I got from ebay. Yesterday I got an email saying he was sending me a decent iron and that it'd be here Saturday. YAY!  :smiley-cool:
My 1st iron, back in 1988 was 220V job with a hood handle, without any kind of regulation it heated like crazy, the point was a cooper(ish) cylinder about 3 or 4mm thick without any kind of coating, that I had to file almost every day because it become pitted and corroded after a few hours of use.
Maybe the electronic solder (as it was called here) back then had acid flux inside instead of rosin or maybe it was just the heat...
I only used it for about 3 months, when I was able to buy a much better one that I still have today.
But in a fix, it would do the job, but you risk the pads and traces specially when trying to remove a component.
polymorph
It wasn't the rosin or flux, it was the solder. Copper is soluble in molten solder. That is why tips are iron plated, now, and why you should never file or sand an iron plated soldering iron tip.
polymorph
I did a teardown of a Tenma branded copy of the Weller WLC100, another lamp dimmer soldering station I would not buy on a dare. Just like the one pictured above, there are dozens of them with different brands printed on them, but all the same.
https://youtu.be/HJynLwsqnts
Having a threaded ring to hold in the tip was a terrible idea, as the heat/cool cycles while using it cause it to unscrew itself, sometimes literally in minutes. The three little dents used to hold in the bit the collar threads onto, similarly loosens itself from heat/cool cycles.
It takes a long time to get to equilibrium temperature, then drops 100F or more while soldering one connection. Then takes around 10 minutes to get back to equilibrium. I find that if I turn it up enough to stay hot enough to solder, it will heat until the tip burns black when back in the holder. So I had to turn it up to use it, turn it back down to put it back in the holder. And keep pliers handy to keep tightening the collar. And watch out for the entire tip/collar/retaining ring falling out. I'm not exaggerating.
#27
Sep 22, 2018, 11:04 pm Last Edit: Sep 24, 2018, 06:00 pm by ocsav
At the time that 'new' tips were called 'long duration' and here (in Portugal) were only available (for the public, it could have been different in the pro market) in fancy brands like JBC. All the cheaper irons just had the cooper rod.
The one I still have is only marked DAHER 30W 220V, the original box is gone, but I am quite sure that I bought it as being a JBC (I can't find any info about but the tips do look like the JBCs, with that small spring on the top), the tip is not the original because I changed it to a smaller one in the 90's but it is still very very shiny.
SaintSkinny
Is the WLC100 a 'lamp-dimmer' too? Or were the clones just putting a rheostat in a similar looking enclosure? the WLC100 is what my Dad sent me, it just came in this afternoon. Either way it's better than the ebay piece I was going to use
Paul__B
I think we can presume that a real Weller will do it properly.
