Here's a function I came up with to do what halley is talking about.
boolean cycleCheck(unsigned long *lastMillis, unsigned int cycle)
unsigned long currentMillis = millis();
if(currentMillis - *lastMillis >= cycle)
*lastMillis = currentMillis;
return true;
return false;
Basic usage:
For each event you want to deal with, set up an unsigned int for how often it should trigger in ms (cycle), and an unsigned long to keep track of the last millis() reading since the last event (lastMillis). You call the function passing the address of the lastMillis for that event and the cycle for that event. The function returns a true if the event is due for action, and a false if the syscle time hasn't elapsed yet.
Typical usage example (Simple blinking 2 LEDs at different rates)
#define ledPin1 11
#define ledPin2 12
#define led1Cycle 100U
#define led2Cycle 275U
unsigned long led1LastMillis = 0;
unsigned long led2LastMillis = 0;
boolean led1State = false;
boolean led2State = false;
return true;
return false;
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
if(cycleCheck(&led1LastMillis, led1Cycle))
digitalWrite(ledPin1, led1State);
led1State = !led1State;
if(cycleCheck(&led2LastMillis, led2Cycle))
digitalWrite(ledPin2, led2State);
led2State = !led2State;
I've found this to work very well, and it keeps the main loop code very clean. You can even make the cycle times variable by making them variables instead of #defines. Then you can change the cycle times during execution. For example, you want to change the blink rate with a potentiometer.
