Topic: My counting method to control a servo does not loop; not sure how to fix (Read 488 times) previous topic - next topic
Preezus
Hello all!
I am seeking help with my program. My goal is to count a blinking LED to a desired amount (in this case 9 times) and then trigger a servo motor with one arm to sweep from 0 degrees to 180 degrees without delay and remain in that 180 degree position until another count of 9 is achieved. So basically I would like my program to loop back and forth and have the servo sweep back and forth but only after 9 blinks of an LED using a count. Here is the code:
Code: [Select]
#include <Servo.h>;
int ledPin =  13;         // LED connected to digital pin 13
const int servoPin = 9;      // Servo connected to digital pin 9
Servo myservo;
int maxnum1 = 9;     // Blink the LED
int count = 0;       // Our blink counter
int pos = 0;          // first position of servo arm
int pos2 = 1;           //second position of servo arm
                        // The setup() method runs once, when the sketch starts
void setup()   {
                                // initialize the digital pin as an output:
  pinMode(ledPin, OUTPUT);
  pinMode(servoPin, OUTPUT);
  myservo.attach(9);
  if (count > 8)
    for (pos = 0; pos <= 180; pos += 1) {      // goes from 0 degrees to 180 degrees
                                                // in steps of 1 degree
      myservo.write(pos2);                        // tell servo to go to position in variable 'pos2'
  if (count < maxnum1) {
    digitalWrite(ledPin, HIGH);                // set the LED on
    delay(500);                                 // wait for a second
    digitalWrite(ledPin, LOW);                    // set the LED off
    delay(499);                                     // wait for a second
    count++;                                  // add one (1) to our count
PaulS
Code: [Select]
All that is code accomplishes is
Code: [Select]
   myservo.write(180);
Why are you using a for loop to do that?
Quote
What does it currently do, and how does that differ from what you want?
Preezus
Currently, the program does not repeat. I would like it to repeat.
The LED blinks 9 times and then the servo motor is activated to position 2. Then the program ends.
I would like it to blink 9 times, activate servo motor to position 2, blink 9 times, activate servo to position 1, blink 9 times, activate servo motor to position 2, and so on...
DKWatson
Read your own post and think about it. You want to blink the LED 9 times,
Code: [Select]
for (byte i = 1; i <= 9; i++)
    delay(499);
Done.
Now you want to move the servo.
Code: [Select]
myservo.write(pos);
Done. Now loop, but before you do, change pos.
Code: [Select]
if(pos == 0)
    pos = 1;
    pos = 0;
Or use the ternary statement,
Code: [Select]
pos = (pos == 0)?1:0;
Or simply negate,
Code: [Select]
pos = !pos;
Live as if you were to die tomorrow. Learn as if you were to live forever. - Mahatma Gandhi
PaulS
Quote
Or simply negate,
That would be challenging if the positions to move to are 60 and 90. Or 0 and 180.
Preezus
I implemented Watson's code.
The LED blinks constantly now without stopping, but the servo still only changes position after the first 9 blinks, not with blink 18, blink 27....
PaulS
Quote
But failed to post it.
Quote
Well, that is what it should do.
Quote
Then I think it is safe to assume you did something wrong.
Preezus
Sorry about that, Paul.
Code: [Select]
    delay(499);
  myservo.write(pos);
  if (pos == 0)
    pos = 1;
    pos = 0;
AWOL
Can you really see the difference.on a servo between 0 "degrees" and 1 "degree"?
Maybe "  myservo.write(pos * 180);"
Preezus
DKWatson
Preezus
How could I use a push button to control the counter here?
Code: [Select]
 for (byte i = 1; i <= 5; i++)
    delay(499);
DKWatson
What? You want the flash to continue, push a button a move the servo?
Preezus
I used the flash as more of an identifier for the test program. It is not required in what I am trying to accomplish, but does add a nice aesthetic touch.
I would like the push button to move the servo after 5 clicks.
PaulS
Quote
The for loop controls the index. Do you want to use the switch to change the upper limit? From what to what? When the switch IS pressed? Or, when the switch BECOMES pressed?
What have you tried? Posting here is the least effective method of achieving your goal. Reading the documentation and experimenting is far better and faster.
