Topic: Firmware for MEGA (Read 1 time) previous topic - next topic
hugo007
Hello all
I'm using ubuntu on my Arduino Mega with the bug on serial Port busy.
Today I try to update the firmware but I cant find the firmware for it
Can someone give me the .hex for Mega?
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
MarkT
Its in the 0022 release in the hardware/arduino/firmwares/ directory I believe.
Also here's the howto page: http://arduino.cc/en/Hacking/DFUProgramming8U2
hugo007
#2
Mar 29, 2011, 06:22 pm Last Edit: Mar 29, 2011, 06:23 pm by hugo007 Reason: 1
Thanks
Until I was waiting for some tip I had found the solution to the problem very well explaned
I found this info
I have tested it and my board is back to live :)
I got the firmware from here:
https://github.com/arduino/Arduino/tree/master/hardware/arduino/firmwares/arduin...(click on the right firmware, then click raw, then save it)
Reflashing the firmware on the 8u2 is a little tricky. Don't try this unless you are prepared to risk bricking your board completely!
You need the dfu-programmer utility:
sudo apt-get install dfu-programmer
Then follow the instructions here to get the Uno into DFU mode:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285962838/10#10
Then to flash the firmware, do this:
sudo dfu-programmer at90usb82 erase
sudo dfu-programmer at90usb82 flash --debug 1 Arduino-usbserial-uno.hex
sudo dfu-programmer at90usb82 reset
Finally unplug the USB plug, wait a few seconds, plug back in.
Here is also the .hex ready to upload to the board
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
