Topic: Arduino BT DC Power Source (Read 958 times) previous topic - next topic
ayf123
Hi all,
I am somewhat new to arduino and am trying to figure out if its possible to connect the Arduino BT to a DC power source. I want to make sure before I invest in this solution. Im creating an installation and need to be able to power the arduino via an electrical outlet.  I read that using more than 5.5v will fry the board. If I use a 5v DC adapter, what does the Amperage need to be?
would something like this work?
http://www.sparkfun.com/products/8269
Thanks in advance.
CrossRoads
Yes - you will need to connect to the 5V pin, not the barrel jack connector.
ayf123
Thanks for your reply. So in the case of the sparkfun dc power supply, could I just cut off the barrel jack and connect the wire straight into the 5V pin? Sorry if this is a stupid question, Im just having a hard time understanding how this should work. Thanks.
CrossRoads
Yep. Measure first, make sure not to install backwards.
