Topic: Declare array of String (Read 137009 times) previous topic - next topic
cantore
Hello, do you know how can I declare an array of the type String (notice the upper case S).  I want to do something like this:
Code: [Select]
String result[SENSOR_NUMBER]; where SENSOR_NUMBER is a constant. Thanks
robtillaart
Sounds like it should work.
What is the value of SENSOR_NUMBER?
remember Strings and their manipulation are RAM hungry and an Arduino has 2K
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
cantore
Thanks for your reply. SENSOR_NUMBER is an int, I think value can be between 5 and 10 for example. I don't know why but declaring the array of sting in this way all the string are corrupted!
cantore
I prefer to use the String type because if not I must use somthing like this:
Code: [Select]
const int maxSize=10;
char result0[maxSize] = "uno";
char result1[maxSize] = "due";
char result2[maxSize] = "due";
char *pointer[3];
  pointer[0]=result0;
  pointer[1]=result1;
  pointer[2]=result2;
where maxSize make me lost a lot of memory. This depends on the fact that my strings are not constant and during the program they will be longer than the string declared for first. I also need to access strings in a loop and using this solution I have to adopt a pointer. So if it would be possible to declare a String vector it will be easier.
robtillaart
your question is about Strings and your code example is about char array's. These are different datatypes.
Think you need something like
Code: [Select]
#define ARRAYSIZE 10
String results[ARRAYSIZE] = { "uno", "duo", "tri" };
  for (int i =0; i< ARRAYSIZE; i++) Serial.println(results[i]);
Rob Tillaart
johnwasser
If you are using string constants, the compiler can count so you don't have to set aside a fixed amount of space:
Code: [Select]
char *pointer[] = { "uno", "due",  "due"};
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
cantore
Code: [Select]
this is possible only if I know the content when I am declaring the string
jraskell
Show us the code you're using that is corrupting the strings.
cantore
May be I have understood my problem. The way of declaring the array of string
Code: [Select]
String result[NUMBER_OF_SENSORS];
should be correct. The problem of string corruption should be that my sketch seems to use more than 2KB of ram. I need to use an arduino mega for testing the system.
