Topic: Optiboot now at version 8.0 (Read 2063 times) previous topic - next topic
westfw
Optiboot version 8 is available.
The major points relevant to Arduino users include:
  • Cleanup of the MCUSR (reset reason) behavior.
  • Ability to jump to the bootloader "as a service" to reload new code (with a bit of care.)
  • an available do_spm() function that allows an application to write to flash memory by calling code withing the bootloader.
Other changes:
  • update switches for more recent compiler versions (as consequence is that it no longer quite works with WinAVR or the IDE1.0.3 compiler.)
  • Add options and "help" target to makefiles.
  • Fold in Hans's (MCUDude's) miniCore, megaCore, mightyCore, and majorCore to support a very large number of ATmega targets.
  • Fold in DrAzzy's ATtinyCore, to support a bunch of the more capable ATtiny targets.
  • On targets with 1k bootloaders, include text info about the build in the binar
  • Make sure the "Virtual Boot Partition" targets work (needed for (4), but... other platforms too!)
  • Add and update test tools and sketches.
  • with a bit of luck, you COULD compile an ATmega328 Optiboot that includes EEPROM read and write capability that still fits in 512bytes (but you have to turn off the do_spm feature, and removing the startup LED blinking.)
  • Various internal cleanups and generalizations.
Most of this work has been available for a long time now, from MCUDude, DrAzzy, and/or Majekw.  I've just finally gotten around to including it in the "master" Optiboot tree.
There is a .json package for the board manager on the release sub-page, but it's become quite minimal compared to the targets and options that are supported.  Unless you want to mess with the source code or build a bootloader with a particularly strange combination of features, it is a much better alternative to use one of the "board" definitions from MCUDude or DrAzzy that include a wide variety of .hex files of the bootloader, AND "core" code to support the processors.  (MCUDude's cores contain several thousand permutations of optiboot*.hex files for different baud rate, processor clock rates, and uart choice.
ron_sutherland
As far as I can tell the combination of optiboot, avrdude, and the nDTR capacitor trick is nearly impossible to break. No matter how I messed up the program I can just bootload a new one (nothing gets locked and blocks a new upload). This is so important for firmware development, and few seem to get it right.
Thanks for sharing the work @westfw and others.
my projects: https://github.com/epccs
DrAzzy
#2
Sep 25, 2018, 05:06 am Last Edit: Sep 25, 2018, 05:06 am by DrAzzy
Thanks.
If life ever is so kind as to stop throwing bullshit at me for long enough that I can catch my breath, I intend to update optiboot and also add support for all the UART-less attiny boards.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
westfw
Heh; it took ME long enough to merge in YOUR code...
Wait a bit longer, and I'll probably convert the tiny targets (and makeall.tiny) to use MCUDude-style parametric looping and hex file naming (like "optiboot_atmega328pb_UART_38400_8000000L.hex")
In the occasional battles over who is responsible for the success of Arduino, I don't think that either the authors of the bootloaders, or the decision to figure out how to use a bootloader that permitted "upload" from any operating system, get nearly enough credit.  Being able to used an Arduino "plugs and play" was SO important!
DrAzzy
Man. By the time I get to it, I think I'm going to need to get help from you on how to work with it....
pert
I also should be noted that Optiboot now supports ATmega2560:
https://github.com/Optiboot/optiboot/commit/7bed5c9c5238a3602f2a43aa4ad78ff76bc53de8
Thanks to everyone for the great work on this project! I'm very glad to see the development work all unified in one project.
hansibull
Awesome!
It would be great if you were able to update the documentation. Most of it seems kind of outdated.
MightyCore -  ATmega1284, mega644, mega324, mega164, mega32, mega16, mega8535
Github.com/MCUdude/MightyCore
MiniCore - ATmega8, mega48, mega88, mega168, mega328
Github.com/MCUdude/MiniCore
DrAzzy
I cloned the repo, put it into my build environment (also kicked the compiler version up to the one that came with 1.8.7).  I'm going to try to build new versions of the bootloaders for ATTinyCore, and see if I can make it work with the soft UART option on the 84/861/88.
1. Which vector is it choosing to use to jump to the program code when using virtual boot on the boards defined in makefile.tiny?
2. I added an entry for the tiny84 by copying the entry for the 841. But now a bunch of defines not used for the attiny841 are getting pulled in: (note that I've kept my omake.bat, which is pointed at the files in the location I use them in - it's the skeleton of a 1.0.6 install for make, but with the compiler updated)
Code: [Select]
c:\arduino-1.0.6\hardware\arduino\bootloaders\optiboot_bld>omake attiny841at8
c:\arduino-1.0.6\hardware\arduino\bootloaders\optiboot_bld>..\..\..\tools\avr\utils\bin\make OS=windows ENV=arduino attiny841at8
c:/arduino-1.0.6/hardware/tools/avr/utils/bin/make attiny841     AVR_FREQ=8000000L BAUD_RATE=57600
make[1]: Entering directory `c:/arduino-1.0.6/hardware/arduino/bootloaders/optiboot_bld'
avr-gcc (GCC) 5.4.0
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
BAUD RATE CHECK: Desired: 57600, Real: 58823, UBRRL = 16, Difference=2.1%
../../../tools/avr/bin/avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=attiny841 -DF_CPU=8000000L  -DBAUD_RATE=57600 -DLED_START_FLASHES=3          '-DVIRTUAL_BOOT_PARTITION' '-DFOURPAGEERASE'    -c -o optiboot.o optiboot.c
optiboot.c:355:6: warning: #warning BAUD_RATE off by greater than 2% [-Wcpp]
../../../tools/avr/bin/avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=attiny841 -DF_CPU=8000000L  -DBAUD_RATE=57600 -DLED_START_FLASHES=3          '-DVIRTUAL_BOOT_PARTITION' '-DFOURPAGEERASE'  -Wl,--section-start=.text=0x1d80 -Wl,--section-start=.version=0x1ffe -Wl,--relax -nostartfiles -o optiboot_attiny841.elf optiboot.o
../../../tools/avr/bin/avr-size optiboot_attiny841.elf
   text    data     bss     dec     hex filename
    596       0       0     596     254 optiboot_attiny841.elf
../../../tools/avr/bin/avr-objcopy -j .text -j .data -j .version --set-section-flags .version=alloc,load -O ihex optiboot_attiny841.elf optiboot_attiny841.hex
..\..\..\tools\avr\bin\avr-objdump -h -S optiboot_attiny841.elf > optiboot_attiny841.lst
rm optiboot_attiny841.elf optiboot.o
make[1]: Leaving directory `c:/arduino-1.0.6/hardware/arduino/bootloaders/optiboot_bld'
mv optiboot_attiny841.hex optiboot_attiny841at8.hex
mv optiboot_attiny841.lst optiboot_attiny841at8.lst
vs 84
Code: [Select]
c:\arduino-1.0.6\hardware\arduino\bootloaders\optiboot_bld>omake attiny84at8
c:\arduino-1.0.6\hardware\arduino\bootloaders\optiboot_bld>..\..\..\tools\avr\utils\bin\make OS=windows ENV=arduino attiny84at8
c:/arduino-1.0.6/hardware/tools/avr/utils/bin/make attiny84      AVR_FREQ=8000000L BAUD_RATE=19200
avr-gcc (GCC) 5.4.0
<command-line>:0:0: warning: "LED_START_FLASHES" redefined
<command-line>:0:0: note: this is the location of the previous definition
BAUD RATE CHECK: Desired: 19200, Real: 19230, UBRRL = 51, Difference=0.1%
../../../tools/avr/bin/avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=attiny84 -DF_CPU=8000000L  -DBAUD_RATE=19200 -DLED_START_FLASHES=3    -DLED_START_FLASHES=0      -DSOFT_UART -DVIRTUAL_BOOT_PARTITION -Dsave_vect_num=4 -DBAUD_RATE=19200 -DLED_START_FLASHES=3    -DLED_START_FLASHES=0      '-DVIRTUAL_BOOT_PARTITION' '-DSOFT_UART'    -c -o optiboot.o optiboot.c
../../../tools/avr/bin/avr-gcc -g -Wall -Os -fno-split-wide-types -mrelax -mmcu=attiny84 -DF_CPU=8000000L  -DBAUD_RATE=19200 -DLED_START_FLASHES=3    -DLED_START_FLASHES=0      -DSOFT_UART -DVIRTUAL_BOOT_PARTITION -Dsave_vect_num=4 -DBAUD_RATE=19200 -DLED_START_FLASHES=3    -DLED_START_FLASHES=0      '-DVIRTUAL_BOOT_PARTITION' '-DSOFT_UART'  -Wl,--section-start=.text=0x1d80 -Wl,--section-start=.version=0x1ffe -Wl,--relax -nostartfiles -o optiboot_attiny84.elf optiboot.o
../../../tools/avr/bin/avr-size optiboot_attiny84.elf
    568       0       0     568     238 optiboot_attiny84.elf
../../../tools/avr/bin/avr-objcopy -j .text -j .data -j .version --set-section-flags .version=alloc,load -O ihex optiboot_attiny84.elf optiboot_attiny84.hex
..\..\..\tools\avr\bin\avr-objdump -h -S optiboot_attiny84.elf > optiboot_attiny84.lst
rm optiboot.o optiboot_attiny84.elf
mv optiboot_attiny84.hex optiboot_attiny84at8.hex
mv optiboot_attiny84.lst optiboot_attiny84at8.lst
Why are all those extra defines tacked onto the front of it?
Also, why is there a UART baud check referring to UBBRL when using SOFT_UART?
This is what I added to the makefile.tiny
Code: [Select]
# ATtiny 84, base instructions
HELPTEXT += "target attiny84     - atttiny841at<freq>  attiny841at<freq>ser1\n"
HELPTEXT += "                     - atttiny841at8_5v  attiny841at8_5vser1\n"
HELPTEXT += "                     - atttiny841at<freq>noLED\n"
attiny84: TARGET = attiny84
attiny84: MCU_TARGET = attiny84
attiny84: CFLAGS += $(COMMON_OPTIONS) '-DVIRTUAL_BOOT_PARTITION' '-DSOFT_UART'
attiny84: AVR_FREQ ?= 8000000L
attiny84: LDSECTIONS  = -Wl,--section-start=.text=0x1d80 -Wl,--section-start=.version=0x1ffe
attiny84: $(PROGRAM)_attiny84.hex
ifndef PRODUCTION
attiny84: $(PROGRAM)_attiny84.lst
endif
attiny84at8:
$(MAKE) attiny84 AVR_FREQ=8000000L BAUD_RATE=19200
mv $(PROGRAM)_attiny84.hex $(PROGRAM)_$@.hex
ifndef PRODUCTION
mv $(PROGRAM)_attiny84.lst $(PROGRAM)_$@.lst
endif
Thanks!!
westfw
#8
Oct 06, 2018, 07:09 am Last Edit: Oct 06, 2018, 07:17 am by westfw
Quote
Well, THAT would be a bug!
The "Clever" code that checks baud rate accuracy does NOT check for SOFT_UART.  (It doesn't actually produce any code, either, so it's not a very serious bug.)
westfw
Quote
SPM_RDY_vect_num, probably.  The code says:
(Hmm.  WDT might not be a good choice...)
Code: [Select]
// Vector to save original reset jump:
//   SPM Ready is least probably used, so it's default
//   if not, use old way WDT_vect_num,
//   or simply set custom save_vect_num in Makefile using vector name
//   or even raw number.
#if !defined (save_vect_num)
#if defined (SPM_RDY_vect_num)
#define save_vect_num (SPM_RDY_vect_num)
#elif defined (SPM_READY_vect_num)
#define save_vect_num (SPM_READY_vect_num)
#elif defined (WDT_vect_num)
#define save_vect_num (WDT_vect_num)
westfw
Quote
Note that there is already a "tiny84" entry in Makefile.extras; a holdover from the Luminet board.
Having another entry in Makefile.tiny will cause both sets of rules to be followed, possibly resulting in two images (for example "make atmega168" generates both an optiboot_atmega168.hex from the old makefile, and a optiboot_atmega168_UART__.hex from Makefile.mcudude.)
It looks like the warning about redefining LED_START_FLASHES comes from an attempt I made to have the tinys default to START_FLASHES=0 if no LED=pinname was mentioned.   Sigh.
In general, the old style of the makefiles was to define a new board by having a full set of make targets, like you do in the current attinycore:
Code: [Select]
attiny1634at12: TARGET = attiny1634
attiny1634at12: MCU_TARGET = attiny1634
attiny1634at12: CFLAGS += $(COMMON_OPTIONS) '-DVIRTUAL_BOOT_PARTITION' '-DFOURPAGEERASE'
attiny1634at12: AVR_FREQ ?= 12000000L
attiny1634at12: LDSECTIONS  = -Wl,--section-start=.text=0x3d80 -Wl,--section-start=.version=0x3ffe
attiny1634at12: $(PROGRAM)_attiny1634at12.hex
attiny1634at12: $(PROGRAM)_attiny1634at12.lst
While the new style is to have each "board" do a recursive make with a target processor and appropriate options:
Code: [Select]
attiny1634at12:
"$(MAKE)" attiny1634 AVR_FREQ=12000000L
mv $(PROGRAM)_attiny1634.hex $(PROGRAM)_$@.hex
ifndef PRODUCTION
mv $(PROGRAM)_attiny1634.lst $(PROGRAM)_$@.lst
endif
(Where the "base" definition of "attiny1634" has the CPU-specific options like "-DVIRTUAL_BOOT_PARTITION' '-DFOURPAGEERASE'  ... -Wl,--section-start=.text=0x3d80  ")
DrAzzy
#11
Oct 06, 2018, 11:22 pm Last Edit: Oct 06, 2018, 11:22 pm by DrAzzy
Okay, thanks. Most of these chips don't have SPM_RDY; will modify that part to check EE_RDY after SPM_RDY.
westfw
Quote
Ahh.  That's the problem with code that tries multiple things - without any messages, it can fall over into unexpected behavior...
Speaking of which, is there a relatively easy "sanity check" for baud rate vs F_CPU that would work for the SOFT_UART platforms?
westfw
makeall.tiny.sh has lines like:
Code: [Select]
make attiny841 $*
make attiny841at184 $*
make attiny841at147 $*
make attiny841at110 $*
make attiny841at921 $*
where each of those is a Makefile target - all consistent with the original make structure (and recursive Makes as I mentioned in the previous post.)
If you look at makeall.mcudude.sh instead, you'll notice that it's "algorithmic" at the shell-script layer, essentially logically:
Code: [Select]
   for (cpuAndUart in <listof CPU and each UART they have>)
      for (freqAndBaud in <list of CPU frequencies and baud rate>)
         make $cpuAndUart FreqAndBaud
         mv target <destination dir and filename based on parameters.>
(The original also ends up building 4000+ .hex files, which seems a little excessive, which is why many of the freqAndCpu options are commented out in the main optiboot repository.)
Which I really like, but doesn't quite work for the tinys because of the way the internal clock frequencies vary between the different chips.
DrAzzy
#14
Oct 07, 2018, 03:55 am Last Edit: Oct 07, 2018, 04:27 am by DrAzzy
Argh! EE_RDY is in the second page on the 841! (and it doesn't get caught by the test for that because you test against SPM_PAGESIZE, when the vector numbers are word addressed but SPM_PAGESIZE is bytes
(edit) Haaaa! I think I got it
No idea on sanity check for SOFT_UART baud rates. I think we'll need to see how far we can push it, then back off enough for safety, and make that the test.
