Topic: inconsistencies between project 1 and 2,3 (Read 2420 times) previous topic - next topic
montana63
I'm trying to not skip anything and going deep into details of each projects and there's something I can't get my head around.
On project 1 the resistance is connected to the anode leg of the LED whereas it's connected on the cathode for projects 2 and 3.
In my mind it all made sense to have the resistance on the anode so it's limiting before hitting the LED so it doesn't blow up because of too much current however seeing the resistance connected to the cathode doesn't really make sense to me as it looks like full current is going through the LED and then it's being limited by the resistance.
I'm sure I'm wrong but I just can't understand why.
Thanks for your feedback
pert
It doesn't matter which side you put the resister on. It's a circuit.
montana63
thanks Pert, "it's a circuit" it actually doesn't make sense to me.
I understand the classic convention is having everything going from + to - I guess this is where I'm getting confused.
pert
The resistor is there to limit the amount of current that can flow through the circuit.
Think of a valve on a water hose. No matter where on the hose that valve is, it still limits the water flow.
It's just like if you had a switch on the LED circuit. Whether the switch is on the anode side of the LED or the cathode side, the light will still turn off when you open the switch because then the charge can't move through the circuit.
