Topic: Write template on Fingerprint sensor R305/R307 (Read 6860 times) previous topic - next topic
nimit393
Blank sketch with Rx Tx correctly connected to that of fingerprint sensor would not work? The code posted by you does a very similar task, with not directly bypassing the UART commands but relaying it to different serial port.
What might be the reason for this?
nimit393
Baud rate for Cool Term can be updated to 57600.
J-M-L
I've seen boards behave differently when trying to use pin 0 and 1 and also have usb connected... so I'm always careful on such setup
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
nimit393
I extracted fingerprint template using the standard extract feature in Ada fruit library. Received template as
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
However, I can find 3 header message within the templates. I tried other fingerprint in the same device...all 3 have 3 header section embedded into it and long series of 0 and F. Which part of the message is actually the template which I can use and write it on to other fingerprint sensor.
Motive is to extract template and store in a central repository...which can be transmitted on to multiple sensors as the network get expanded.
J-M-L
Post the full true output of the example - not just an extract of what you think is meaningful
Are you running this on a UNO or MEGA ?
The  stray FFFFFFFFFFF you see are just there because buffer is initialized with plenty of FF in the library
They seem to use data packets of 256 bytes but seems what you get back is actually the 128 bytes version
having multiple data packet is not impossible as you might not be able to fit all the data in one frame, so you should expect when you send a command to get many answer and at some point the last frame will include a End of Data packet command so that you know it's the last one
there is  plenty of garbage so would need to see exactly the output on the Serial console...
The 3 frames you see are
EF01
FFFFFFFF
02      Data packet
0082      length of package = command packets + data packets + CKSUM --> 128 bytes + 2 for checksum
056C      CKSUM (this one is OK)
EF01
FFFFFFFF
02      Data packet
2AF9      CKSUM (this one seems wrong)
EF01
FFFFFFFF
08      End of Data packet
0618      CKSUM (this one is OK)
nimit393
The attachment shows template read for 2 different fingerprints.
However when I am trying to write the same template on other location...the serial trace does not show garbage values but cool term shows. And after sending the 4 chunks of template...finally when store command is used...reply is 01 ...error when receiving data.
nimit393
Issue resolved...I am now able to write template from external source. You can ignore the above post.
J-M-L
Would be fair to explain what you did and how you solved it for everyone having the same question in the future
nimit393
1. First step to extract fingerprint from sensor is to load the desired template number to either buffer 1 or 2.
2. Once the template is loaded into buffer, read the template from buffer.
3. Template size might vary, hence, the whole template might be broken down into multiple bits and part.
4. This template can now be stored onto other device and can be reused to write the same template into similar sensor.
5. Commands for all the above functions are standard and can be viewed in the document shared in this blog post above.
6. Example of template extracted can also be viewed in the text files shared in the previous post.
J-M-L
nimit393
Trying to send data over serial. The data is getting transmitted as ASCII equivalent when read over the other arduino with code shared by you in earlier post(one which displays the HEX values of the data received over serial). However, correct HEX value get displayed on the serial monitor of the arduino on which this code is runing.
Code: [Select]
  SD card read/write
 This example shows how to read and write data to and from an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN)
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
#include <SPI.h>
#include <SD.h>
int i;
String s;
char a[1]={16};
int b=20;
File myFile;
  Serial.begin(57600);
  mySerial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  myFile = SD.open("ABCDEF.txt", FILE_WRITE);
  // re-open the file for reading:
  myFile = SD.open("ABCDEF.txt");
  if (myFile) {
    Serial.println("ABCDEF.txt:");
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      i=myFile.read();
      if (isDigit(i)) {
      // convert the incoming byte to a char and add it to the string:
      s += (char)i;
    if (i == '\n') {
      int p = s.toInt();
      Serial.print(p,HEX);
      mySerial.print(p,HEX);
      p=atoi(p);
      s = "";
      p = "";
      //mySerial.print(32,HEX);
      //Serial.write(r);
      //mySerial.write(r);
    // close the file:
    myFile.close();
    // if the file didn't open, print an error:
    Serial.println("error opening ABCDEF.txt");
  // nothing happens after setup
  //mySerial.write("1");
nimit393
Understood my mistake...should had used Serial.write instead of Serial.print
J-M-L
marcoas
@nimit393,  Can you show us, the code for write template on sensor, please?
