I'm a newbie with Arduino, but experienced with FPGA's.
I purchased an MKR Vidor and tried to go through the installation instructions. I have a Windows 7 OS and I'm not sure the drivers were installed correctly. However, the IDE recognizes the board and port.
I try the uploading the blink example and it hangs. Here is the message:
Arduino: 1.8.7 (Windows 7), Board: "Arduino MKR Vidor 4000"
Sketch uses 10820 bytes (4%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM6
PORTS {COM3, COM4, COM6, } / {COM3, COM4, COM6, } => {}
Uploading using selected port: COM6
C:\Users\fphiggins\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM6 -I -U true -i -e -w C:\Users\FPHIGG~1\AppData\Local\Temp\arduino_build_478261/Blink_fph.ino.bin -R
An error occurred while uploading the sketch
The final error message line does not appear until several minutes into the upload. I'm assuming it timed out.
The hardware is blinking a red led at 1 second intervals (this is not from the software being correctly uploaded).
The IDE version is: 1.8.7
The SAMD beta board version is: 1.6.24
What can I do to debug this?
Thanks,
Frank Higgins
