Topic: Really having difficulty connecting to my Yun Console.  (Read 593 times) previous topic - next topic
hahnsolo
I can't seem to connect to the Yun console.  I have tried any of the sketeches and had no luck. I get errors ranging from auth issues to io exceptions.
The sketch below generates an io exception
 Console ASCII table for YunShield/Yún
 Prints out byte values in all possible formats:
 * as raw binary values
 * as ASCII-encoded decimal, hex, octal, and binary values
 For more on ASCII, see http://www.asciitable.com and http://en.wikipedia.org/wiki/ASCII
 The circuit:
 - YunShield/Yún
 created 2006
 by Nicholas Zambetti
 http://www.zambetti.com
 modified 9 Apr 2012
 by Tom Igoe
 modified 22 May 2013
 by Cristian Maglie
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/ConsoleAsciiTable
#include <Console.h>
  //Initialize Console and wait for port to open:
  Bridge.begin();
  Console.begin();
  // Uncomment the following line to enable buffering:
  // - better transmission speed and efficiency
  // - needs to call Console.flush() to ensure that all
  //   transmitted data is sent
  //Console.buffer(64);
  while (!Console) {
    ; // wait for Console port to connect.
  // prints title with ending line break
  Console.println("ASCII Table ~ Character Map");
// first visible ASCIIcharacter '!' is number 33:
int thisByte = 33;
// you can also write ASCII characters in single quotes.
// for example. '!' is the same as 33, so you could also use this:
//int thisByte = '!';
  // prints value unaltered, i.e. the raw binary version of the
  // byte. The Console monitor interprets all bytes as
  // ASCII, so 33, the first number,  will show up as '!'
  Console.write(thisByte);
  Console.print(", dec: ");
  // prints value as string as an ASCII-encoded decimal (base 10).
  // Decimal is the  default format for Console.print() and Console.println(),
  // so no modifier is needed:
  Console.print(thisByte);
  // But you can declare the modifier for decimal if you want to.
  //this also works if you uncomment it:
  // Console.print(thisByte, DEC);
  Console.print(", hex: ");
  // prints value as string in hexadecimal (base 16):
  Console.print(thisByte, HEX);
  Console.print(", oct: ");
  // prints value as string in octal (base 8);
  Console.print(thisByte, OCT);
  Console.print(", bin: ");
  // prints value as string in binary (base 2)
  // also prints ending line break:
  Console.println(thisByte, BIN);
  // if printed last visible character '~' or 126, stop:
  if (thisByte == 126) {    // you could also use if (thisByte == '~') {
    // ensure the latest bit of data is sent
    Console.flush();
    // This loop loops forever and does nothing
    while (true) {
      continue;
  // go on to the next character
  thisByte++;
ballscrewbob
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
