Topic: Strange result (Probable bug further checking required ?) (Read 176 times) previous topic - next topic
ballscrewbob
Oct 10, 2018, 03:06 pm Last Edit: Oct 10, 2018, 03:08 pm by ballscrewbob
Please see the very last line of the upload msg.
I have added an MKR1000 to my list of available boards.
The correct MKR1000 was selected along with the correct COM port.
It compiles just fine.
The sketch in question is HERE
EDIT:
For some unknown reason it uploaded at the third attempt ?
Code: [Select]
/home/ubuntu/opt/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /tmp/270630864/build/T1_oct10.ino.elf /tmp/270630864/build/T1_oct10.ino.hex
Multiple libraries were found for "MQTT.h"
Used: /home/ubuntu/opt/libraries/latest/mqtt_2_3_3
Not used: /tmp/270630864/custom/arduino_41199
Not used: /home/ubuntu/opt/libraries/latest/cmmc_mqtt_connector_1_1_0
Not used: /home/ubuntu/opt/libraries/latest/azureiothubmqttclient_0_2_3
Multiple libraries were found for "ArduinoCloudThing.h"
Used: /home/ubuntu/opt/cores/arduino/samd/libraries/ArduinoCloudThing
Not used: /tmp/270630864/custom/ArduinoCloud
Not used: /home/ubuntu/opt/libraries/latest/arduinocloud_1_0_1
Using library wifi101_0_15_2 at version 0.15.2 in folder: /home/ubuntu/opt/libraries/latest/wifi101_0_15_2
Using library ArduinoIoTCloud at version 0.0.0 in folder: /home/ubuntu/opt/cores/arduino/samd/libraries/ArduinoIoTCloud
Using library mqtt_2_3_3 at version 2.3.3 in folder: /home/ubuntu/opt/libraries/latest/mqtt_2_3_3
Using library ArduinoIoTCloudBearSSL at version 1.1.0 in folder: /home/ubuntu/opt/cores/arduino/samd/libraries/ArduinoIoTCloudBearSSL
Using library ArduinoCloudThing at version 1.0.1 in folder: /home/ubuntu/opt/cores/arduino/samd/libraries/ArduinoCloudThing
Using library SPI at version 1.0 in folder: /home/ubuntu/opt/cores/arduino/samd/libraries/SPI
Using library arduinoeccx08_1_0_0 at version 1.0.0 in folder: /home/ubuntu/opt/libraries/latest/arduinoeccx08_1_0_0
Using library Wire at version 1.0 in folder: /home/ubuntu/opt/cores/arduino/samd/libraries/Wire
/home/ubuntu/opt/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-size -A /tmp/270630864/build/T1_oct10.ino.elf
Sketch uses 132768 bytes (50%) of program storage space. Maximum is 262144 bytes.
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[COM1 COM37 COM6 COM27 COM3 COM8 COM12 COM11 COM33 COM16]
Touching port COM11 at 1200bps
Set DTR off
Flashing with command:d:/Users/Bob/.arduino-create/arduino/bossac/1.7.0/bossac.exe -i -d --port=COM11 -U true -i -e -w -v d:/Users/Bob/AppData/Local/Temp/arduino-create-agent207282680/T1_oct10.bin -R
Set binary mode
No device found on COM11
Send auto-baud
Set binary mode
readWord(addr=0)=0x2e31206c
readWord(addr=0xe000ed00)=0x5b206631
readWord(addr=0x400e0740)=0x20272427
version()=for help]
chipId=0x20272427
Unsupported processor
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
endorama
I suspect this has nothing to do with the cloud itself and is probably more related to the Create Editor.
@ubidefeo any idea?
ballscrewbob
I only linked it here as I was playing with cloud and an associated sketch at the time.
Would tend to agree it may be better pushed to EDITOR.
Not been able to re-create either which makes it very hard to find out why it did that.
