Topic: HOW TO TURN OFF CHRG  (Read 744 times) previous topic - next topic
rtrisnoj
I have  a project using two sensors and MKR GSM 1400. I only want to use battery to power mkr gsm 1400. Do you have any idea how to turn off the chrg capabilities? Because it seems the board was working for sometimes and suddenly when the chrg was blinking. It went to idle state and when I pressed reset, it works again.
Obviously, in real world when I installed the device in the remote area, I can't keep reset it as I like.
Code: https://github.com/rtrisnoj/US3
Thanks,
RT
ballscrewbob
Do you just mean the Charge LED ?
If so it has always had an "odd" behaviour.
When used with a correct battery pack that changes to better represent the actual properties.
Most people ignore it when connected on USB.
Search the MKR1000 section of the forum where you will find more information on the subject.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
sandeepmistry
What size battery are you using?
rtrisnoj
#3
Oct 11, 2018, 05:14 pm Last Edit: Oct 13, 2018, 03:18 am by ballscrewbob
I don't plan to use USB to power it.
Yes, I mean charge LED. My goal is to use mkr gsm 1400 only powered by non-rechargeable batteries and will last long about 6 months without changing the batteries.
I am using 3.6V Titus battery in series. Therefore, I have around 7.2 V and I connected them in Vin.
Does this one work? It works for me but I don't plan to use LiPo batteries because it won't last long.
Also 4 AA x 1.5V Alkaline battery doesn't work. I plan to add the mAh capacity by adding the 7.2V in parallel to make it last longer for the batteries.
Do you have any alternative or suggestion? Is the board not meant to be use only for batteries?
Thank you,
RT
battery: http://www.titusbattery.com/product/er34615/       in series
ballscrewbob
Modified your link a little
BTW do not forget this is a 3.3 volt board !
Just be careful and check the board spec before you start pushing 7.2 volts around it.
Alkaline batteries never last long enough for Arduino work.
