Topic: PG200 clone with arduino (Read 246 times) previous topic - next topic
Barito
Hi all,
a synthesizer enthusiast in the need for your help here  :)
I am trying to understand how to send appropriate serial messages to a synthesizer (Roland JX3P) in order to emulate the behaviour of a rare and expensive nowadays hardware Roland developed in the mid '80s.
The hardware (PG200) was intended as an interface to send tone parameters to the synth in order to create new sounds out of it.
The protocol has just been studied and valuable info are available. Unfortunately I could not get in touch with the original author.
In a nutshell:
- messages are 9 bit unpaired
- messages are inverted before be sent
- a start message has to be sent for the synth to see them as valid
Here is a link to the whole notes the original author wrote
http://www.xonik.no/mpg-200/pg-200/pg-200.html
Now, sending midi messages with arduino is a joke thanks to the work of arduino communities all over the world and i have realized some hardware myself (see i.e. https://www.google.it/amp/s/www.instructables.com/id/almost-Universal-MIDI-SysEx-CC-Programmer-and-Sequ/%3famp_page=true).
Unfortunately, this is a completely different task and I am in the need for some starting hints from valuable coder.
Could anyone help me in figuring out how to assemble and send those messages with arduino?
Thanks in advance!
pylon
Quote
The UART of the AVR Arduinos is able to send 9bit data. The drawback: The Serial object (HardwareSerial) doesn't support it. You'd have to write your own code for this.
Quote
Seems to be a simple hardware inverter.
Quote
Should be the easiest part.
Barito
Thank you for your answer. Unfortunately I have no idea on how to rewrite hardware serial library (I am a "basic" user, not that advanced).
I have seen an old Gammon library for 9 bit messages: would it be of some use?
I really need some insight on the form of such messages...
pylon
Quote
Sure, but I would apply the patch to a current version of the HardwareSerial class to get all the bug fixes from the last years.
Quote
The linked pages should give you enough inside of the form of such messages. But you cannot use the print() and println() methods of the Stream class as they don't support 9bit characters. Use the write() method for every character sent.
Barito
Thanks.
The author of those pages speak about bytes too, so it's not 100% clear to me if every message is 9 bit or some could be 8 bit... Any though?
pylon
Quote
I'd expect everything to use 9bit characters. It's extremely uncommon to change the bit size of a character during a transmission.
Barito
Thanks. I am waiting for a 6 pin connector to be dropped in my mailbox to start experimenting with this. I will report back!
elliottlan
#7
Jan 18, 2019, 10:40 am Last Edit: Jan 18, 2019, 10:40 am by elliottlan
Any luck with this Barito? (sorry for thread resurrection)
