Topic: Driving proportional solenoid valve using PWM (Read 3092 times) previous topic - next topic
zeus2kx
Oct 11, 2018, 03:23 pm Last Edit: Oct 11, 2018, 03:27 pm by zeus2kx
Hi guys,
I have an old proportional solenoid valve which can be proportionally opened and closed in the supply voltage range of 0-6VDC.
This valve does also support current driving but I want voltage control using PWM (0-5V).
Now how can I use Arduino PWM when I am limited by current?
Can I use easydriver? If so, how do I wire and code?
Thanks.
Z
jremington
You will need a voltage controlled, constant current driver. A motor driver will not work.
Google "arduino proportional valve control" for several forum entries and DIY projects.
zeus2kx
#2
Oct 11, 2018, 09:01 pm Last Edit: Oct 11, 2018, 09:10 pm by zeus2kx
In general Solenoid Proportional Valves (SPVs) are constant voltage (CV) and variable current driven.
In this case I could think of CV and vary the current by a circuit similar to below..
But this is tricky. More than an year ago I tried a different SPV but didn't have much success.
Therefore for this particular valve (tested by bench-top power supply by varying input voltage) I wanted to vary voltage somehow by using arduino PWM.
Without powering this valve, the coil resistance is 5 ohms.
Would you recommend a circuit?
Thanks.
jremington
zeus2kx
They don't support this particular model anymore.
However, they proposed the attached controller.
Robin2
@zeus2kx, for some strange reason you sent me a PM asking me to look at this Thread.
I have nothing to contribute - this stuff is beyond my pay grade.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
zeus2kx
Well, thanks anyway.
jremington
The circuit posted in reply #2 is not a good idea, because the RFD3055 is not a logic level MOSFET.
If you had taken the trouble to do the Google search suggested in reply #1, you would have found this discussion, with suggested circuits, near the top of the list.
zeus2kx
I used FQP30N06L instead.
Its a logic level N-Channel MOSFET with Vgs lower than 3V.
I saw that post you mentioned and luckily I had built this circuit as well in the past. It could only open the valve but not proportionally in the PWM range.
I can rebuild this circuit but kindly suggest changes based on this valve.
Thanks.
jremington
Quote
What circuit?
zeus2kx
jremington
#11
Oct 13, 2018, 12:23 am Last Edit: Oct 13, 2018, 12:24 am by jremington
In order to design a proper control circuit, you either need the valve datasheet, or experiment to determine how much current is required to obtain a certain flow.
The 6V rating combined with the 5 Ohm coil resistance suggests that 1.2 A is required to open the valve fully.
zeus2kx
Exactly.. actually 1A since I want 5V PWM. Valve won't be completely open but that's alright.
So the operating current range is 0-1A.
zeus2kx
I will very appreciate if someone helps me get to a solution.
Thanks.
jremington
#14
Oct 18, 2018, 05:16 am Last Edit: Oct 18, 2018, 05:29 am by jremington
I would modify this circuit to deliver about 1.2A max. To do that, the voltage divider has to deliver 1.2V to the op amp pin 3, when 5V is input. R1=3.3K, R2=1K should produce about 1.16V.
The valve drive and op amp power supply voltage must be greater than about 8V. 10-12V should be OK but you will need a heat sink on the power transistor.
