Topic: trouble with acs712 (measuring ac current) (Read 3045 times) previous topic - next topic
lupamundur
hi guys, i was new to this stuff firstly :D
i've tried bunch of arduino module, and came across this acs712 module (30A) to monitoring my AC current.
here is my goal,
1. i'm trying to monitoring AC current around 3-6 Amp (220v/50Hz) with acs712 and arduino uno
2. set it to turning on fan when reach to 4 Amp with relay module
i've tried many code and modified some but still can't get a fine result, for example i was workng with this code which i get from http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
Code: [Select]
Measuring AC Current Using ACS712
const int sensorIn = A0;
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
void loop(){
 Voltage = getVPP();
 VRMS = (Voltage/2.0) *0.707;
 AmpsRMS = (VRMS * 1000)/mVperAmp;
 Serial.print(AmpsRMS);
 Serial.println(" Amps RMS");
float getVPP()
  float result;
  int readValue;             //value read from the sensor
  int maxValue = 0;          // store max value here
  int minValue = 1024;          // store min value here
   uint32_t start_time = millis();
   while((millis()-start_time) < 1000) //sample for 1 Sec
       readValue = analogRead(sensorIn);
       // see if you have a new maxValue
       if (readValue > maxValue)
           /*record the maximum sensor value*/
           maxValue = readValue;
       if (readValue < minValue)
           minValue = readValue;
   // Subtract min from max
   result = ((maxValue - minValue) * 5.0)/1024.0;
   return result;
when nothing is connected i got reading from my arduino around 0,02-0,03 Amp.
and when i'm connected with 1,7Amp load (reading from my Amp clamp meter), i got around 0,74 Amp from my arduino
my question is acs712 accurate enough to read AC or DC current? or it is more suitable for DC current?
or should i get another current sensor for AC like ta-12-100 or any suggestion to read 3-6 Amp on AC?
:D
pylon
Code: [Select]
Have you read the code and the comments in it or just copy/pasted it? That value must be 66 for the 30A module.
Juraj
acs712 is good for AC. the sketch calculates the amperes from the voltages read from A0. so the calculation is wrong or your wiring
lupamundur
Code: [Select]
i'm just copied the code directly from the web and paste it here. but i'm using "66" in my arduino. sorry not to mention it :D
and it's still showing incorrect accurancy base on my amp clamp meter
i'm doubt it would come from my wiring, as i'm already connected to pin A0.
is it have some problem with my 220v AC? assuming the code is working on 110v AC? idk though. i've trying for 6 hours :D
Juraj
hi juraj, sorry for bothering you. i'm seek for help. i still can't figure it out with my acs712 to measuring current. i've using reading min and max data using this code, and i get min=510, max=512. which mean my acs712 isn't bad (i read in some web, saying it suppose around 512 when not connected)
Code: [Select]
#include <LiquidCrystal.h>
// coder haripinter, elangsakti.com
// ACS 712
const byte sensor = A0;
// Settingan  LCD RS E D4 D5 D6 D7
LiquidCrystal lcd(8,9,10,11,12,13);
int acs_ref_data = 512;
int acs_data = 0;
int acs_data_max = acs_ref_data;
int acs_data_min = acs_ref_data;
int acs_range = 0;
int LIMIT = 5;
unsigned long delay_now = 0;
unsigned long delay_last = 0;
unsigned long delay_limit = 1000;
    pinMode(sensor, INPUT);
    lcd.begin(16,2);
    sensor_listener();
void sensor_listener(){
    acs_data = analogRead(sensor);
    // max data
    if(acs_data > acs_data_max){
      acs_data_max = acs_data;
    // min data
    if(acs_data < acs_data_min){
      acs_data_min = acs_data;
    if(millis() - delay_last >= delay_limit){
      lcd.setCursor(0,0);
      lcd.print("Min: ");
      lcd.print(acs_data_min);
      lcd.print("  ");
      lcd.setCursor(0,1);
      lcd.print("Max: ");
      lcd.print(acs_data_max);
      lcd.print("  ");
      lcd.setCursor(10,0);
      lcd.print("Stat:");
      lcd.setCursor(10,1);
      // for sensor
      acs_range = acs_data_max-acs_data_min;
      if( (acs_data_min < acs_ref_data) &&
          (acs_data_max > acs_ref_data) &&
          (acs_range > LIMIT)){
        lcd.print("ON ");
      }else{
        lcd.print("OFF");
      delay_last += delay_limit;
according to min and max data i get, it has no problem when there is no load. but when i applied 1,9A, i get min=486, max=536. and put it in calculation according to this link link which will be=
           = ((536-486)*5.0)/1024.0
           =0.244
           = (0.244/2.0)*0.707
           =0.0863
                   =  (0.0863*1000)/66 (using module for 30A)
                   =1.31 A (suppose to be 1.9A)
hopefully you can help me :D
you didn't change 5 to 3.3 (volts)
lupamundur
thank you for replying, by 3.3 V are you mean i have to use voltage divider to lower voltage from 5V to 3.3V from acs712 output pin to arduino A0 pin?
Juraj
#6
Oct 13, 2018, 10:37 pm Last Edit: Oct 13, 2018, 10:39 pm by Juraj
sorry I confused threads. You have a 5 V board
Wawa
#7
Oct 13, 2018, 10:38 pm Last Edit: Oct 13, 2018, 10:44 pm by Wawa
? The ACS712 is a 5volt only device, and can only be used with 5volt Arduinos.
You can't display 0.0x amp with a 30Amp hall sensor and Arduino's 10-bit A/D.
There are theoretically only 287 A/D values available to display that 30Amp, so almost a 0.1Amp resolution.
Print to one decimal place. Serial.print(AmpsRMS, 1);
Simple current sensors can be accurate, but only with a resistive load and after calibration.
int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
66 might have to be changed slightly for the display to show the right current value.
Leo..
lupamundur
Leo..
I've seen some of your post! Haha. You also post in some of acs712 case in this forum. I had searching in this forum so deep but still can't figure out how to make this acs712 a little bit accurate.
1. I noticed it will not accurate even slightly 90%
2. I've tried messing with 70,80,90,100 etc
Can you suggest me any method how to monitoring my ac current A/D by my arduino? I just need a little bit precise on 3-5 Amp to triggering my relay, please? :D
Wawa
#9
Oct 14, 2018, 03:35 am Last Edit: Oct 14, 2018, 03:37 am by Wawa
The code from post#0 should work, despite that it takes a detour to get there.
You have picked a sensor with a rather high current rating, making it less suitable to display small currents.
It's wise to calibrate the sensor, e.g. with a 2000watt heater.
I see you live in a 220volt country, so it should display 2000/220 = ~9.1Amp.
Change the '66' value, one number at the time (and re-upload), until you get that current value.
Leo..
Edit: Note that the ACS712, and especially the board it's mounted on, is not really made for 220AC mains power.
Juraj
#10
Oct 14, 2018, 07:56 am Last Edit: Oct 14, 2018, 07:59 am by Juraj
yes. I have it here and always after some time I start to plan how to use it with esp8266 or M0 and then I must 'pull the hand brake' in my mind because I (again) realize it has middle value at 2.5 V.
Quote from: Wawa
It has Hall sensor near the screw terminal. the terminal is good fot thicker cable and the AC doesn't go to PCB I think. I tested it with 2000 W (9 Amp.)
@lupamundur, as I wrote in my first comment, the sensor doesn't measure Amps. it returns some values generated by Hall sensor and circuit on the module. and it is are read by ADC and the result of ADC depends on AREF. the formula is valid, but it needs some calibration value for this unknown factors.
Wawa
#11
Oct 14, 2018, 08:15 am Last Edit: Oct 14, 2018, 08:22 am by Wawa
Voltage is the problem, not current.
The sensor and trace distances on the boards might not comply with local 220/240volt safety regulations.
The ACS712 datasheet mentions 184volt AC max for double insulated (not grounded) devices.
Circuit boards must have a minimum distance between mains and low voltage parts/traces.
I think I have seen 8mm somewhere.
Current transformers (that clip over the insulated wire) should be much safer to use.
Leo..
lupamundur
Leo..
after searching in google and trying to understand the formula of RMS and 0.707 i believe the code is working, and double check acs712 datasheet, it confirmed acs712 work with max voltage 184V, thank you for your help :D
yeah you're right, but again acs712 doesn't seem to work on my 220V. even with calibration, i doubt it would have 70% accuracy.
Leo..
i came to conclusion not using acs712 as ac current, maybe it suitable for my next dc current project. also i have considered using PZEM-004T With Coil 100A 80-260V or TA12-100. both will work with 220V AC, what do you guys think? :D
Juraj
I use Grove Electricity Sensor with TA12-200 for 9 A 230 V
lupamundur
I found this development board on my research and it claimed 32bit adc. Let say voltage around 110V, using this STM32 board and acs712 will this be more accurate? Please comment what you think
