Every second = 1 second.
I use some other gear part to make it slower but stepper motor too powerfull.
Every step like hitting with hammer.
To much vibration = blurry photo
Using the DRV8825 driver you can set the microsteping up to X32. That will make the motion much smoother. Have you tried that? Refer to this Pololu page for how to set the microsteps. You will need to adjust your delay to get the speed that you want.
Yes I heard about microstepping stuff but I just bought arduino and don't know how.
On Pololu web site says set HIGH/HIGH/HIGH but doesn't show how to do it.
Is it on board? or software?
both way I have to ask how.
I'm looking on youtube videos but couldnt find any instruction
It is normal for a stepper motor and a stepper motor driver to be hot - uncomfortable to touch.
Have you set the current limit on your DRV8825 to 1.7A to match your motor?
If, as you suggest, the motor has more torque than your project needs you may find that it works equally well with a lower current setting and that would allow everything to run cooler.
Robin2:
Have you tried reducing the current like I suggested?
If you need low speed the best solution is step-down gearing - perhaps with a toothed belt drive because they don't suffer from backlash.
I don't see how it can be smoother unless it has a finer level of microstepping.
...R
Yes I made the current setting early but didn't make any change now.
I never use TMC2100 or any other driver or Arduino before.
This is my first experience.
Acording to this video TMC2100 very smooth and silent.
TMC2100 can go 1/256 microsteping.
People says when the DRV8825 getting hot it may skip steps.
I even feel some oddness about pulses. Sometime pulses are not clear and sharp.
I like to try TMC2100 and see how its going.
Another topics.
I have Nema 17 1.7A 7,4V 200steps stepper motor.
On spec and theory it's says every step 1.8 degree.
Is it reliable? or is it depend on power source like AC/DC motors.
it is easy to write some code to test for missed steps. I suspect the unevenness is because a micro-step that lands on a full step position will be more precise. Microsteps (with all drivers) are achieved by balancing the pull of the magnets between two full-step positions.
It will be reliable - it is physically built into the motor.
Yes MorganS I will use at least 2 or 4 gear to avoid vibration and making much more slower rotation.
Now.
I bought a TMC2100 driver.
It's awesome.
I guess this is Chinese copy but still awesome.
With DRV8825 I can feel the pulse unstableness (maybe not right word)
With TMC2100 I have a heat problem again but not the driver. Motor getting really hot this time.
I try with Nema 14 7.4V Pololu stepper motor.
First vref was 0.7V an motor was burning after 1-2 min later. Driver was cool without any heatsink
Then I reduce vref to 0.3V motor was hot but ehhh... Also driver a little hot without any heatsink
I guess we calculate the vref x 2 = current limit.
On Pololu web site says Nema 14 "Current rating: 280 mA per coil" Should I set 0.15V or 0.28 for both coil?
Also another thing bugging me.
Right now I'm at home and using a cheezy 12V 2.5A power supply for external power for motor.
But in my mind I like to use this battery "Sony NP FW50" 7,4V 2000mAh. It's also fit my camera so I can use it both way and easy to charge in my bag with USB powerbank.
But this 7.4V will change my vref setting right?
sebatiantr:
There are two vital things missing ...
A link to the datasheet for the stepper motor.
A link to the datasheet for the motor driver.
What I think you are saying is that there is position and torque ripple with microstepping, but its the
best you can do and inherent to the motor itself.
